Sony 42w653a
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Sony 42w653a
    Sony 42w653a I have is blinking three times then a another three times,been told may be the drivers is this correct or a power board fault ? All I know is the tv will not switch on
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: Sony 42w653a
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Sony 42w653a
      Can someone help me test this please,
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: Sony 42w653a
        What voltages do you have or not have on the power supply?
        Focused photo of the power supply?
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          Re: Sony 42w653a
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: Sony 42w653a
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              Re: Sony 42w653a
              Do measure the voltage on the 10 pin connector ?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Re: Sony 42w653a
                So it uses an external power supply to power the internal combined mainboard/power supply.
                There appear to be a number of fuses marked on the board. Have you located and checked each one.
                Have you checked the incoming voltage from the external power supply is 19.5V when connected to the tv.
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  Re: Sony 42w653a
                  It uses a power supply similar to a laptop,I have not checked as wanted some advice how do do this,I'm armed with a multimeter,I know you ground the black and test with the red,set to dc volts ? So little bit of help I am a quick learner...
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Re: Sony 42w653a
                    That's correct.
                    To test the fuses, set switched off and meter set to ohms, place your red and black probe on each side of the fuse and it should measure 0 ohms or close enough for a good fuse.
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      Re: Sony 42w653a
                      Thank you for the advice,when testing the input voltage,can the set be on (currently only flashing when on) be best to start to see if right voltage is coming through
                        Re: Sony 42w653a
                        Voltage, yes the set needs to be plugged in, else you'd measure zero.
                        Ohms, no. Some cheap meters can be damaged by measuring ohms when voltage is applied. Most are okay, just not the very cheapest. In any instance, it will not give you an accurate reading.
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          Re: Sony 42w653a
                          Just measured the power input only on two pins measuring 19.2 of 19.5 power supply,can I have more asssitance please
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            Re: Sony 42w653a
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              Re: Sony 42w653a
                              Tested c1004 fuse nothing,on the board 4.ld standby does that equal to this fuse maybe ?
                              • YasaCh
                                Sony kdl 40p5500 red light keeps blinking 3 times
                                by YasaCh
                                Hello...
                                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                i opened the back cover no sign of damage on the powery suply or motherboard
                                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                07-07-2025, 11:53 AM
                              • shahnld
                                Sony kdl 65xg9505 green amber blinking
                                by shahnld
                                Good Day.
                                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                01-03-2024, 03:05 PM
                              • CSM123
                                Sony KDL-55HX850 - Blinking 3x
                                by CSM123
                                Have KDL-55HX850 that seems to have been hit by power surge.
                                Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                Replaced Power Supply G board - same response.
                                Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                Checked speaker impedances ok 8ohms each.
                                Where are JL6002, JL6005 test points?
                                Ideas for what next to troubleshoot?
                                Could it be T-Conn or LED board? Seems that the troubleshooting...
                                02-06-2024, 11:50 AM
                              • sickboy
                                Strange CRT Fault (Sony Trinitron M1410U)
                                by sickboy
                                This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                                11-10-2024, 05:02 AM
                              • YasaCh
                                sony kd-49xf9005 4 red blinking problem
                                by YasaCh
                                Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                05-05-2025, 08:40 AM
