Panasonic dlp tv
  • ser4320
    • Jun 2011
    Panasonic dlp tv
    DLP turns Off
  • mostachio
    Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
    by mostachio
    Hi Badcaps,
    I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
    TV Details:
    Model # - TH-65DX700Z
    Symptoms:
    The television turns on and displays a picture then makes a clicking sound and turns off.
    I haven't opened it up yet but...
    09-04-2024, 02:32 AM
  • PanasTC
    Panasonic TC-60CX800U turns off after 2 seconds.
    by PanasTC
    Panasonic TC-60CX800U with Power board: TNPA6060 1P
    The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
    Also, I could see HDM in the top corner for a second.
    Is it possible that the issue is a bad LED light that forces the TV to turn off?​
    11-27-2023, 09:02 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
    by Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
    03-15-2024, 09:37 AM
  • www
    LG L192WS-BN backlight turns off after 1 second
    by www
    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
    03-24-2024, 05:26 PM
