Tips for removing big LCD screens
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    As I have seen on here that the new leds are going bad more and more often. I just wanted to see if anyone had tips to remove the LCD panel when replacing a led so the panel doesn't break. I have done up to 42" but even that made me weiry. I have a 50" to do and not looking forward to it
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Tips for removing big LCD screens
    You would need to use the glass handling suction cups....only way
    • chrismurphy
      • May 2014
      • 251
      • australia
      remove t-con connections
      Place tv on its back
      Remove screws around the panel front cover ,remove cover
      Using masking tape secure LCD panel to the plastic frame in a few places to hold panel into frame
      Unclip locking tabs and remove panel with frame to safe place
      Using masking tape secure plastic diffusers together and mark alignment to back frame
      Remove diffusers to safe place
      Repair backlights etc
      Replace in reverse order
      This is how i do 55 to 60 LG
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        That's what I currently do for the 42"-46". It's hard enough to lift that. I might look into some glass suction cups.
        • mmartell
          • Oct 2013
          • 3189
          Face down.
          • zomi
            • Nov 2011
            • 512
            https://www.aliexpress.com/item/4-su...709187199.html
            if you doing alot
            • dskall
              • Oct 2016
              • 2905
              • usa
              You can also prop tv at around 45* with panel pcb facing up and lift off with little stress
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • woody-009
                Tips on how to remove a very stuck memory chip on a GPU?
                by woody-009
                Hi Everyone
                I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
                So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the...
                05-10-2022, 02:54 AM
              • Kemer
                Graphics Card mounting frame
                by Kemer
                Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                What worries me right now is the possibility that...
                09-14-2024, 08:57 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • mecha1166
                Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                by mecha1166
                Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                06-13-2024, 02:28 PM
