Le32r88bd
  • jonny78
    • Apr 2017
    • 72
    • United Kingdom
    Le32r88bd
    Hi Guys got this set for free ( ive had a few of these) and as its ten years old ive replaced all caps on the power board replaced a few on the mainbaord too ( ones which are prone to fail)..eveything works fine except theres a weird problem...the picture mode has to be DYNAMIC and the backlight has to be fully up to the highest setting of 10..if i change the picture mode to standard or movie the screen will start flickering and if i lower he backlight to anything less than full it will also start flickering! Here's somebody else's video with the exact same problem :
    https://www.youtube.com/watch?v=PUucR5yOY5c
    ive swapped out the inverter and mainboard for working spares i alreadyy had and it doesnt make any difference!!
    has anybody experienced this before?
    power board is BN44-00191A
    main board is BN41-00813B
  • Hamie
    • Apr 2014
    • 1383
    Re: Le32r88bd
    Probably one or more of the ccfl's are beginning to fail.
    Had numerous older LCD TVs where there was a pot on the inverter that you could crank up and the backlight would stay on.
      Re: Le32r88bd
      It sounds like the EEPROM settings may be corrupt, try a factory reset from the service menu.
      To enter service menu put TV in standby then press (in sequence) Info, Menu, Mute, Power on the remote.
      • jonny78
        • Apr 2017
        • 72
        • United Kingdom
        Re: Le32r88bd
        Cheers for the replies...its all sorted now...reset didnt work but what did work was changing the panel settings inside the service menu!
        • microso
          • Oct 2016
          • 13
          • Romania
          Re: Le32r88bd
          Please, can you write here what panel settings you use to solve this?
          Thx.
            • 12104
            • U.S.
            Re: Le32r88bd
            Whats the history of the tv, do you know if anyone has ever had the back cover off??
            • vinceroger69
              • Mar 2012
              • 6714
              Re: Le32r88bd
              Thx.
              maybe lowering backlight settings if you can i know this is a ccfl set but still worth a try
              • microso
                • Oct 2016
                • 13
                • Romania
                Re: Le32r88bd
                Factory reset not work, less backlight either, when i select dinamic or film instead of standard mode i get image with colour mixed and edges with high contrast. I manage to adjust video settings in standard mode and set of colours "cold1" and get a verry foggy picture.
                I think to change the T-con board.
                Can anyone tell me what series of t-con is in this pictures?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  Re: Le32r88bd
                  did you see this video is this the symptoms your seeing?
                  https://www.youtube.com/watch?v=nK8_p7FU9-M
                  https://www.aliexpress.com/w/wholesale-v315b1-c01.html
                    • 12104
                    • U.S.
                    Re: Le32r88bd
                    Should be able to find it on that page, just make sure you match up the numbers on your white sticker, don't know if you have ebay in Romania, maybe go to a similar site: https://www.google.com/search?client...M%2435-D013932
                    • microso
                      • Oct 2016
                      • 13
                      • Romania
                      Re: Le32r88bd
                      Thx for your quick answers.
                      All is the same like in the video.
                      I make order for this part, and and let you know here for result.
                      Thx again.
                      • reessi
                        ACER BM320 Monitor - Horizonal Flickering Lines After a While
                        by reessi
                        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                        They are black on the right and gradually fade to nothing on the far left.
                        They start either after 5 mins or up to 2 hours after so annoying for testing.
                        They flicker continuously very fast! With a slight pause milli-second every second.
                        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                        I tested each half by removing the first the left flex from...
                        06-03-2025, 09:58 AM
                      • DrvLikHell
                        Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                        by DrvLikHell
                        Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                        The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                        07-05-2024, 02:54 AM
                      • Jaysean
                        Acer VN7-591G-70RT Display Flickering
                        by Jaysean
                        Hello Badcaps coummunity hope you all are having a bless day,
                        Hope I didn't post it wrong kinda new at forum site rules and tradition
                        So I'm dealing with screen flickering problem on my laptop.
                        I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                        so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                        [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                        [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                        10-27-2023, 10:22 AM
                      • arctor
                        LG 55uh661v flickering images and lines
                        by arctor
                        Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                        06-16-2025, 11:57 AM
                      • Adenitz
                        Cutting the jumper on Samsung TV to solve the flickering
                        by Adenitz
                        Hello to all,
                        I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
                        But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
                        Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
                        01-06-2024, 12:20 PM
