Samsung UN40J5200AFXZA
  • dogdad
    • Nov 2015
    • 35
    • usa
    Status light continually blinks whether on/off has been pressed on remote. No picture, no backlight and no sound.
    If I try to change source with the remote, the status light will do a rapid flicker for a couple seconds and then go back to the regular blink.
    'ShopJimmy' doesn't show any parts for the tv.
    Suggestions?
    On Edit: Just realized, is that status light doing some kind of blink-code?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Samsung UN40J5200AFXZA
    Measure voltages incl. pin out names so we have something to go by...
      09-07-2024, 05:50 AM
    • Kemer
      Led status indicator light transfer plastic
      by Kemer
      Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
      There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
      The plastic piece doesn't appear to be broken.
      1. What are your suggestions for resolving this issue?
      2. Is the plastic piece made of special ma...
      08-19-2025, 07:02 PM
    • marcinq
      Samsung UE60KS7000 No Standby Light
      by marcinq
      I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
      I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
      05-26-2025, 11:36 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
    • jesterace
      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
      by jesterace
      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
      Tried installing latest firmware but no change.
      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
      10-26-2022, 02:20 AM
