Samsung ln40c630k1fxza no backlight
  • curranb
    • Aug 2017
    • 16
    • Usa
    I'm looking for help with my Samsung ln40c630k1fxza. The set powers up, has sound but no picture. However, shining a flashlight on the screen reveals that there is a picture just no backlight. The last few times the set had been used the screen flickered for a few seconds at startup until a normal picture appeared. Now it will not light.
    After reading several threads on this issue in this forum and others I took a chance and replaced the power supply capacitors that have been known to fail in these sets. Unfortunately there was no change.
    I've downloaded the schematic for the power supply (bn44-0034b) from this site. Below are the readings at the connector that runs to the main board:
    Pin Desc. Reading
    1. B13v. 13v
    2. 5v_DET. 0v
    3. B13v. 13v
    4. BLU_ON 2v
    5. B13v. 13v
    6. E-PWM. 5v
    7. GND. 0v
    8. H_SYNC. 0v
    9-10. GND. 0V
    11. B5v. 5v
    12. GND. 0v
    13-14. B5v. 5v
    15. B13v. 13v
    16. A5v. 5v
    17. B13v. 13v
    18. PS_ON. 1.5v
    I also took measurements at the connector to the inverter board
    1. Vcc B12v. 13.24v
    2. FB2. 0v
    3. FB1. 0v
    4-5. GND. 0v
    6. LD. 12.38v
    7. LD. 12.38v
    All readings were with the tv powered up. Any ideas or next steps?
    Thanks.
    Re: Samsung ln40c630k1fxza no backlight
    "bn44-0034b" Recheck the P.N, it is not correct number; we also need to see the picture of it too. It may be just bad dc blocker/coupling cap.
    • curranb
      • Aug 2017
      • 16
      • Usa
      Thank you for the reply. Power Supply Model is I40F1_ADY. Code is BN44-00340B.
      Please see the attached photos. The caps I've already replaced are the 9 in the lower left corner of the 1st and 3rd pics and the upper right of the 2nd pic.
        I am talking about DC blocker/coupling cap CI802 in the inverter section.
        Fuse FI801S is good?
        If you turn the TV on in the dark room, do you see the backlights even flash on for seconds?
        The BLU-ON is a little on the low side.
        Do you have about 390VDC measured right between the two legs of one of the two yellow main filter caps when TV is turned on?
        • curranb
          • Aug 2017
          • 16
          • Usa
          I will check the capacitor and fuse when I get home tonight. I had checked the voltage of the two large yellow capacitors in standby and on as described in a previous thread and found both readings were good. I will also double check.
          I've started the tv with room darkened several times and haven't seen any flashes - the screen is always pitch black.
          • curranb
            • Aug 2017
            • 16
            • Usa
            OK. I removed the fuse and cap you mentioned and both were good. Any other ideas? I really appreciate any thoughts you may have.
            • curranb
              • Aug 2017
              • 16
              • Usa
              And I rechecked the yellow caps and was getting 385v at each.
                OK, so the boosted Voltage is OK, one thing we can try is to bypass the PFC Under Voltage protection, see the picture attached.
                You can short out the photo transistor of the Opto PCS804S to see if that will allow the Inverter circuit to come on or not, we know that the PFC Voltage is normal so it is OK to bypass the protection just to be sure that we do not have faulty protection circuit due to bad Opto or resistors that drifted their values. Make sure to look at the diagram really well to make sure you do that to the correct Opto on the board.
                • curranb
                  • Aug 2017
                  • 16
                  • Usa
                  Great. I"ll give that a try tonight. Thanks.
                    OPTO LTV817M spec.
                    • curranb
                      • Aug 2017
                      • 16
                      • Usa
                      OK. I shorted the pins you mentioned together - still nothing. Not sure if this helps but I took voltages at the 4 pins of the photo coupler and they are as follows (using the pin numbers found on the photo coupler data sheet):
                      1 -54.7 V
                      2. -55.8V
                      3. -6.9 mV
                      4. -7.2 MV
                      Note that all voltages are negative with regard to ground.
                      • R_J
                        • 9627
                        to measure the voltage correctly, pin 1 & 2 are reference to HOT ground (ie black lead of meter on negative of cp801/803) Pin 3 & 4 you can use the chassis as ground
                        If you disconnect the main board from the power board (cn802) and plug in the power, do the back lights come on? (not sure if this works on this model but worth a try)
                        • curranb
                          • Aug 2017
                          • 16
                          • Usa
                          Thank you for your help RJ. Using the - of CP801/803 as hot ground
                          Pin 1 = 3.0 V
                          Pin 2 = 1.9V
                          Using chassis ground
                          Pin 3 = -6.9 mV
                          Pin 4 = -7.2 mV
                          I've tried disconnecting the main board from the power supply but it doesn't light.
                            Pin 1 = 3.0 V
                            Pin 2 = 1.9V
                            Pin 3 = -6.9 mV
                            Pin 4 = -7.2 mV
                            That cannot be right, pin 3 and pin 4 per spec sheet of the opto are the Photo Transistor side which are in the cold side of the circuit, and it is fed by 5.2 power supply through QI815 (KRA104S) which should be on to supply about 5V to the EN pin of the backlights PWM IC.
                            So to have mV at pin 3 and pin 4 it can either be that QI815 (KRA104S)is bad or it is not turned on by QI814 (2N2222, NPN).
                            Start checking DCV on those two Transistors when BL-ON is present.
                            Notes: those pin number assignment in the diagram may not match the spec sheet of the Transistors.
                            You do have 5.3V in that section of the circuit, right?
                            See schematic for more details.
                            BTW, I see that the power supply has pull-up resistors RS861 for the PS-ON and RI868 for the BL-ON which means you can self-test the power supply board by itself without having the cable connected between the power supply board and the main board.
                            • curranb
                              • Aug 2017
                              • 16
                              • Usa
                              I double checked the voltages at pins 3 and 4 and they are definitely what I previously posted. In the attached picture pcs804s is the nearest photo coupler in the row of four and pins 3 and 4 are on the right. Out of curiousity I measured the right hand pins on the other 3 photocouplers (cold side) and the readings were between 1 and 5 volts. The transistors you mentioned are on the backside of the board and very small - if they're in need of replacement I think that would be beyond my soldering skills! If you believe that readings are indicative of a power supply board problem and not an issue with another component (i.e. main board, etc) I'm thinking the best solution might be for me to just replace the PSB. What do you think?
                                That is correct, the right side is the cold side of the circuit and they are pin 3 and pin 4 so I expect to see about 5V on those pins when BL-ON is present. So it is either the 5.3V power supply is not working or bad Transistor. At this point based on your Voltage readings, the power supply board does have problem in that section.
                                • curranb
                                  • Aug 2017
                                  • 16
                                  • Usa
                                  Do you have any recommendations of where to purchase a new or refurbished PSB?
                                    I use shopjimmy.
                                    • curranb
                                      • Aug 2017
                                      • 16
                                      • Usa
                                      Thank you very much for all your help. I really appreciate it.
                                        09-07-2024, 05:50 AM
                                      • sansanpartida
                                        Samsung QE82Q70RAT no backlight
                                        by sansanpartida
                                        Hi everyone!
                                        Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                        My issue: No backlight.
                                        Model: QE82Q70RAT
                                        Type No: QE82Q70RAT
                                        The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                        So hopefully, I can fix this cheaper.
                                        05-22-2024, 06:56 AM
                                      • howardc64
                                        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                        by howardc64
                                        TV was fixed just after removing Samsung's rear snap cover.
                                        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                        Maybe PSU->backlight connector didn't have a good contact?...
                                        07-23-2025, 12:34 AM
                                      • howardc64
                                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                        by howardc64
                                        • Prior owner tried a replacement main board. No difference.
                                        • Samsung 2x red blinking standby LED = panel fault
                                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                        07-19-2025, 10:54 PM
                                      • Ierwin
                                        by Ierwin
                                        05-13-2025, 03:31 PM
