RCA LED65G55R120Q mainboard compatibility question
  • ghertech
    • Aug 2017
    I'm currently working on an RCA LED65G55R120Q Mainboard Model 65120RE01M3393LNA19-B4, not my first rodeo with this series of TV's. Most are pretty easy to source parts for. However this one.. Had to replace the power board as it was bad. Now the TV has power but LED's do not come on, so I'm thinking "great another dead RCA mainboard" we all know there is like 200 versions of this exact mainboard. So I called shopjimmy, no go never stocked it. I search and search nobody has this beast.. The Question is.. Does it have to be a B4 board? or can I use another in the B series? or even A series? as long as the model is right? all the other repairs on this TV model I've done were all -A? models easy to source boards for.. Any help here? Thanks in advance..
    BTW this was a customers and is now mine as they didn't want to pay to get it fixed, and I'm now on a mission to fix this thing..
    Thanks again..
    Ryan (Ghertech)
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: RCA LED65G55R120Q mainboard compatibility question
    Not getting the bl_on command?
    • ghertech
      • Aug 2017
      Clarify please, I can't get anything from this mainboard. I would swear from the damage this TV had to the power board (components broken off and loose) that it was either hit by a massive power surge, or lightening. No signs of physical dropping. Am I missing something? What and how am I supposed to read this command? FYI, all LEDS check out good as well. Thanks for helping here.. I've never had to go console on any TV I've worked on. I'm a soldering guy. I replace parts and most the time things just work.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
        Format:
        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
        1 - XXXXXXX - XXv - XXXv
        2 - XXXXXXX - XXXv - XXXv
        3 - XXXXXXX - XXXv - XXXv
        4 - etc.
        And pictures
        • bohaboha
          SAMSUNG MAINBOARD COMPATIBILITY BN41-02751B
          by bohaboha
          Hello everyone, hope you have had a lot of sun and a nice summer.
          I wonder and hope that these two Mainboards are compatible because they look like twins. one Native is BN41-02751B.000 and the same thing on the other printed on the circuit but they differ what is on the stick Native BN94-16627N the other BN94-16103q. don't know if the region issue can cause problems
          or maybe it's a dump question or even a settings question for them to fit
          is there anyone here who can help me sort out this question very thanksm...
          08-04-2025, 05:42 PM
        • Mirenia
          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
          by Mirenia
          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
          03-30-2025, 06:47 AM
        • orcic
          MASTER TL240 and new mainboard LW36BKC01
          by orcic
          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
          Now I have some doubts about how to connect the new mainboard to the old power supply.
          First of...
          05-12-2023, 08:10 AM
        • Malva
          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
          by Malva
          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
          Mainboard model: EAX65684604
          PCB marking: EBT62954607
          SPI chip: Winbond W25X20CLNIG Problem description:
          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
          • I bought another
          06-25-2025, 02:07 PM
        • Devonavar
          Vizio M43-C1 - How closely do I need to match the mainboard number?
          by Devonavar
          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
          So, I've ruled out the PSU for now.
          The reboot loop...
          08-14-2022, 08:46 PM
