RCA LED television trouble
  • GusC
    • Jul 2017
    • 7
    I have a three year old 55" RCA TV. Model # LED55G55R120Q. I have no image. I also lost sound but I replaced the power board and now I have sound but still no image.
    When I shine a flashlight near the screen I can see images so I think the back lights are not working. I'd like to replace the panel that controls the LED lights but I don't know which panel does that.
    Besides the power panel I see two other panels in the back. One is model # RE55R011-A1. The other is model # 55120RE01M3393LNA35-C1 and all the accessory plug ins are in it.
    Any idea which of these boards controls the back lights? Thank you.
  • R_J
    • 9588
    Re: RCA LED television trouble
    You could post some pictures of the boards etc. Maybe the power board is different or bad? From what I can tell the power supply,supplies the voltage for the backlights. ther is also a backlight ON control line that comes from the main board (the one with the inputs)
    so if the power supply is ok then I suspect there are some bad led's in the panel
    • GusC
      • Jul 2017
      • 7
      Thank you, R J.
      I just replaced the power board so I hope it is good.
      I will get pictures and post them.
      • GusC
        • Jul 2017
        • 7
        Here are pictures of the back of the TV and panels. I just replaced the power board (on the right).
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          With the set up and running can you measure BL-ON voltage (CON4, pin 3) and also the voltages on the led connector CON5 and post the results.
          Code:
          CON4
          Pin 3  BL_On = xx.xV
          Con5
          Pin 1  Led-  xx.xV
          Pin 2  NC
          Pin 3  Led+  xx.xV
          Pin 4  NC
          Pin 5  NC
          Pin 6  Led-  xx.xV
          Pin 7  Led+  xx.xV
          At switch on the voltage on the led connector may well peak but then drop quickly so if you have a min/max function on your multimeter that would help. Try and catch the maximum voltage on each pin of CON5 at switch on.
          • GusC
            • Jul 2017
            • 7
            Thank you Dick Barton.
            This will take a while. I'll have to find me a meter. I'm not into all this stuff so I don't own tools. I'm not afraid to try and fix stuff, either.
            I just don't wan to throw away a three year old TV. My option is to take it to a repair shop if I fail in my quest.
            • GusC
              • Jul 2017
              • 7
              Well. I took the TV to a repair shop. The gentlemen who owns it seemed very experienced and upfront with me.
              After a couple of days he called me to tell me he did not think it was worth fixing it. He explained that one or more LEDs are burnt out. He told me he tested it and got one side (half) of the panel to come on.
              He explained that the panel would have to be replaced and if we could even find it, it would be expensive. He thought those panels were no longer made.
              His estimate to fix it was around $200, again, if we could even find the panel.
              Considering the TV is only 3 years old I think it would be worth repairing it but I'd have to find another repair shop to take it to. This one guy does not want to mess with it.
              Any thoughts out there, suggestions, ideas?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                It would seem odd that both leds burnt out and panel fault at the same time although it is possible.
                The burnt out leds can be replaced and there are plenty of Youtube video's showing how to do it or buy replacement strips from someone like Shopjimmy.
                Check once again with a bright light that you can see a full picture on the panel to establish that it's only a backlight problem.
                • CapLeaker
                  Leaking Member
                  • 8325
                  x2
                  Gets my vote too. I'd be checking that panel situation out again by myself.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    i would think that you just have some bad led's and the guy who you took it too did not want to open up the panel, so told you that the panel was shot.
                    if i was you, i would open it up myself and have a better look at things.
                    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                    • GusC
                      • Jul 2017
                      • 7
                      I really appreciate all the input. I feel the same way. there's gotta be a way to fix it and not necessarily expensive, either. I'm just not knowledgeable in electronics. Anyway I will try it and hopefully I'll be able to tap into all the knowledge in this forum.
                      I'll start with the bright light on the screen. I'm sure I have image but I'll check it again.
                      Thank you for all your help.
                      BTW anybody in north east PA?
                      As for the rhetorical question about Phillips, I can't post the answer.
                      • Simplebeans
                        Blaupunkt 236/2071-GB-3B-HKDUP-UK stays in standby
                        by Simplebeans
                        I am currently attempting to repair this television.
                        Currently the television stays in standby mode (red light on the television) even after attempting to switch it on via the remote control or controls on the television itself. I have opened the television up and there was a electrolytic capacitor that looked bad therefore replaced this however this has made no difference and the same issue still persists.
                        I am now thinking that this could be a EPROM issue? If yes, i have not yet been able to locate a EPROM dump for this make and model of television, if anyone can help...
                        07-25-2025, 04:51 PM
                      • Francesc V.
                        Christmas lights - Something I am doing wrong
                        by Francesc V.
                        Hi:
                        i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                        I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                        If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                        Could...
                        03-11-2023, 07:38 AM
                      • bialag
                        Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                        by bialag
                        I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                        Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                        03-25-2025, 05:56 PM
                      • gabrielA7
                        IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                        by gabrielA7
                        Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                        I saw that the room LED lights up only when the screen is connected, so quiet.
                        We have all the power supplies, even processor, 1.8V
                        One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                        I suspect that there may be some leak in the processor.
                        Anyway, when I press the power, it...
                        10-29-2024, 06:48 AM
                      • evilkitty
                        When your mom is complaining about her new cheap lights
                        by evilkitty
                        My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                        well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                        lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                        07-23-2024, 01:27 PM
