Blaupunkt 236/2071-GB-3B-HKDUP-UK stays in standby
  • Simplebeans
    • Sep 2021
    • 135
    I am currently attempting to repair this television.
    Currently the television stays in standby mode (red light on the television) even after attempting to switch it on via the remote control or controls on the television itself. I have opened the television up and there was a electrolytic capacitor that looked bad therefore replaced this however this has made no difference and the same issue still persists.
    I am now thinking that this could be a EPROM issue? If yes, i have not yet been able to locate a EPROM dump for this make and model of television, if anyone can help on this or has any other suggestions of the cause of this issue?
  • lotas
    • Jan 2016
    • 4865
    • Russia
    What motherboard do you have, not this TP.MSD308C.PA501? Post here your original, faulty dump.
    • lotas
      • Jan 2016
      • 4865
      • Russia
      It's clear, apparently it was necessary.
      • Simplebeans
        • Sep 2021
        • 135
        The circuit board is a T.MSD309.B66B. Do you still need the EPROM dump or is one available already?
        • Simplebeans
          • Sep 2021
          • 135
          Just got the faulty EPROM dump, please see attached.
          • lotas
            • Jan 2016
            • 4865
            • Russia
            Your software in dump is fine, try with clean NVM.
            • lotas
              • Jan 2016
              • 4865
              • Russia
              Doesn't work?
              • Simplebeans
                • Sep 2021
                • 135
                Perfect!, tried this EPROM dump and the television is now swiching on and working. Just out of interest what programmer do you currently use?, i have a RT809F ISP Serial Programmer.
                • lotas
                  • Jan 2016
                  • 4865
                  • Russia
                  I have about 15 different programmers, but I don't need them to diagnose your dump...
                  • cockalomg
                    Blaupunkt blaupunkt b32she188tchd-100 no standby light
                    by cockalomg
                    Does anyone have a schematic for this board?
                    I have no output voltages, no standby voltages.
                    The fullbridge rectifier has a permanent 330V
                    there is no voltage on the two large black electrolytic capacitors​
                    11-05-2024, 03:01 AM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • truztruz
                    TV "BLAUPUNKT"32/122I-GB-5B-HBKU-EU - ok standby - blue led on for a few seconds
                    by truztruz
                    Hello to all,
                    I'm trying to repair a TV model "BLAUPUNKT" 32 / 122I-GB-5B-HBKU-EU with mainboard TP.MSD309.BP75.
                    Red standby is present.
                    By pressing the power button, the blue led lights up for several seconds (about 6 seconds) but no sign of TV life (no backlight and no video signal on the panel (verified with a flashlight)
                    The LED then returns to red and then returns to blue and so on (the flashing is not fast, but as mentioned, several seconds pass between red and blue)
                    I measured the voltage on the main output...
                    12-01-2021, 04:19 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
