backlight issue Samsung UE32EH5000
    Re: backlight issue Samsung UE32EH5000
    Originally posted by Mikeyboy2007
    checked those voltages. im now suspecting failed IC ?
    Pin 1 - VCC 13v
    Pin 12 - ENA 0v
    Pin 15 - ADIM 0.8v
    Pin 16 - BDIM 0.8v
    Are these Voltage tested when the TV is turned on? I do not expect to see boosted Voltage of 182V if ENA (Enable) pin at 0V.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      #42
      tv turned on and LEDs connected Budm
        Hmm that does not make sense since you do have Boosted VoltAge of 182VDC. At this point I would take a chance on replacing that IC because right now that internal MOSFET for the LED current return is not being turned on or the MOSFET has failed.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          #44
          ENA needs to be 1.22V or greater to operate and switches off if less than 1.15V
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            #45
            ok thanks. would this do ?
              That is why it does not make sense to me since he is getting the Boosted Voltage without having ENA control, may be it is measurement error.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #47
                Pin 1 - VCC 13v
                Pin 12 - ENA 0v
                Pin 15 - ADIM 0.8v
                Pin 16 - BDIM 0.8v
                I too get 0v on enable from what I recall, so perhaps you're having the same issue as I do: that 704 FET going bad and pulling down the enable line. After I killed it by forcing 5v on BLU_ON, I now DO get around 3v on BLU_ON and the backlight does come on, but I'm obviously not leaving it like that. The FET is open-circuit now so I think that actually "did it". Although it was not shorted before, it might explain why it smoked when I applied 5v to it...something was not quite right. I'm surprised it didn't smoke earlier when the TV put 5v on it, since that's what the main board does when it turns on to trigger the backlight :| I shall try replacing that first, since it's cheaper and easier than replacing the IC.
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #48
                  I too get the same 180v output voltage, so I would concur the IC is fine. Something in the "enable" circuit is acting up. Also, how come 180v is not lighting up anything ? My variac lit up the entire TV with around 110v. Is it the current that's too low ?
                  Wattevah...
                    That is because it is either the Internal MOSFET for the Catode LED current return line inside that IC is bad or it is not being driven so the LED will not light up. That is why you cane take a chance replacing the IC and see what happen.
                    Spec sheet page 11: Analog Dimming ( ADIM, the range is between 0.3~3V, so 0.8V is OK. BDIM (PWM dimming) must be OK otherwise the boost converter will not be working.
                    Also look at this thread:
                    https://www.badcaps.net/forum/showth...FAN7340&page=2
                    Also check the current sensing resistor on pin 8 to make sure it is OK.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      #50
                      Most likely not driven, since the LEDs do light up if I put 5v on the BLU_ON pin of the PSU (at the increased risk of burning something up even more). If I leave it floating (with that SOT-23 transistor now open), it flashes, so would that mean the IC is good ? I ordered one anyhow, but I'll start with replacing the transistor first...I sure hope 704 stands for 2n7002k.
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #51
                        Ok, replaced the SOT transistor and it's still not working sadly, so that was just a side-effect Another thing I noticed is that the voltage going to the LEDs (the blue wire) is a bit too high: with the LEDs connected, it goes to 230v, whereas those caps are only rated for 200v...should I bother to replace the caps ? Somebody suggested doing so in a local forum...don't know whether it actually fixed anything or not. My buddy could not find the IC at the local "radioshack" so if someone manages to find it and replace it, please at least let me know if it works.
                        Wattevah...
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          As a quick test could you just tie the ENA to REF which is at 5V using a 10K resistor without the SOT in circuit and then check the voltages and see if the leds come on
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #53
                            Here are my readings, with no hacks, no straps and nothing complaining:
                            ENABLE: 3v
                            REF: 5v
                            ADIM: 0.8v
                            BDIM: 1v
                            230v on the "send" blue wires, around 130 on the Drain pins of the IC (the "return" black wires). Measurements taken with respect to chassis ground. If I measure across the LED output connector, with negative on black and positive on blue, I get a random reading that jumps around between 0 and 1.4 or thereabouts....Dead FET inside the IC perhaps ? :| Just because the readings are in spec, doesn't mean the IC is fine internally, like BudM suggested.
                            Wattevah...
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #54
                              If you disconnect the leds do you have an open circuit voltage still of 230V on the blue wire?
                              What resistance do you read between Pin 8 and ground (Sense resistor)
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                #55
                                The sense resistor reads 3.3 ohms which is correct. The voltage at the output is present and identical regardless of whether the LEDs are connected or not: slowly rising to 230v (presumably the PSU is trying to meet the set current by increasing the voltage on the load but stops at an upper threshold). The small connecting cable is OK because I applied power with my variac and the strips came on. I even moved it around when the PSU was plugged in to ensure it wasn't just a one-off occasion where it conducts in one orientation but stops conducting when it's moved or twisted.
                                Wattevah...
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #56
                                  It does make me think that the internal mosfet has failed as Budm has already suggested as a possible cause of the problem.
                                  I haven't done this before so I don't know if it's a good idea but if you quickly short Pins 8 & 9 (shorting the drain/source of the internal mosfet) do the backlights come on?
                                  • thoma
                                    • Sep 2012
                                    • 268
                                    https://www.youtube.com/watch?v=KHBdZqGhMTg[
                                    http://www.berlin-repariert.de/samsu...270-kein-bild/
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      #58
                                      i will try that and report back. i have ordered a replacement IC also so should be here tomorrow morning.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        #59
                                        Great. I ordered mine too eventually from somewhere else but will have to wait till next week, so please let me know how things go
                                        Wattevah...
                                        • Dannyx
                                          CertifiedAxhole
                                          • Aug 2016
                                          • 3912
                                          • Romania
                                          #60
                                          Have you made any more progress on this TV ?
                                          Wattevah...
                                          • Kjell
                                            Samsung Series 9 - BIOS issue
                                            by Kjell
                                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                            08-01-2025, 09:15 AM
                                            09-07-2024, 05:50 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
