Help with HDMI chip identification !
  • 964758
    • Jul 2017
    • 40
    • Georgia
    Hi ! I've Samsung LE40B530P7WXRU. Doesn't works all HDMI. I want to change HDMI chip. Please help me with HDMI chip identification. Photo I attached. Many thanks in advance !
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Help with HDMI chip identification !
    Possibly IC303. Put the markings on it into a search engine to confirm.
    • 964758
      • Jul 2017
      • 40
      • Georgia
      Thanks for reply ! Did you mean IC3003 ?
      Please see the picture, that I attached
      • 964758
        • Jul 2017
        • 40
        • Georgia
        The WT61P8 is a microcontroller for flat panel display control and power management with 1) Turbo 8052 CPU, 2) 64K bytes flash memory, 3) 1K+256 bytes SRAM, 4) 8 8-bit PWMs, 5) DPMS detector(2 H/V inputs, Support H+V input) , 6) 4 timers and 2 UART Ports, 7) 2 DDC/CI interface, 8) Slave I2C interface, 9) 8 channel 8-bit A/D converter, 10) Real Time Clock, 11) Watch-dog timer, 12) Embedded ISP function, 13) Power down mode, 14) Embedded ICE mode. 15) H/W CEC
        http://www.weltrend.com.tw/en-global...tail/66/77/220
        • diif
          • Feb 2014
          • 6978
          • England
          I did mean that IC but then I can't see the markings of the whole board.
            The D600x parts near the HDMI connectors are just protection diodes and unlikely to be the fault
            If the traces route themselves into the main processor, you have no chance of repairing it because that's probably BGA with custom firmware.
            • 964758
              • Jul 2017
              • 40
              • Georgia
              It is SEMS12 with 324 balls.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Your hdmi ports look different. Have you examined ports for damage?
                • 964758
                  • Jul 2017
                  • 40
                  • Georgia
                  Yes I examined
                  • ngth82
                    • Jul 2015
                    • 541
                    Can you post a clear picture of the entire main board?
                    See the top diff pair traces that go from each HDMI connector? They head north, but we need to see the entire board. follow those traces and that's where the HDMI controller is located.
                    EDIT: Did you pick this TV up, or is this TV yours? What happened to it?
                    Please post a picture of the entire board. How many HDMI ports do you have? only 2? 3? 4? Do any of the other ports work?
                    I'm curious because on some TV sets, HDMI 1/2 are passed through a HDMI multiplexer, while HDMI 3, for example, is a direct input to the video processor. If your TV has just an issue with an HDMI mux, then it's easy to just replace the SMT part and get going again.
                    If the inputs go directly to the video processor and neither ports work, then you'll have a tougher time trying to figure that out.
                    What have you tried doing so far? If you haven't already:
                    1. Ohm out the traces between the HDMI connector - check for shorts
                    2. Ohm out the trace between the HDMi connector, and the protection diodes.
                    3. Ohm out the protection diodes from one side to the other.
                    4. Ohm out the trace from the protection diode to the HDMI chip (which isn't shown in your pic).
                    5. Check the power supplies on the board - find the datasheet for the HDMI chip, and see if hte associated pins have power (measure across the capactors around the device).
                    6. post a picture of the entire main board so we can get a good idea of the topology.
                    Do that and report back
                    Thanks!
                    -Thomas
                    -Thomas
                    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                    • 964758
                      • Jul 2017
                      • 40
                      • Georgia
                      Many thanks for the reply ! But I don't have the board at this time. I take the photo from other board, where doesn't work TV tuner.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Follow the hdmi traces from the connectors. In your pic they disappear out the top of the pic. They either go to a switching ic or to a microprocessor, in which case the functions are integrated.
                        • 964758
                          • Jul 2017
                          • 40
                          • Georgia
                          Many thanks for reply !
                          • olegeisler
                            • Dec 2016
                            • 100
                            • Denmark
                            It is a SEMS 12, located under the heatsink. Unless you have proper equipment + skills for BGA rework you are out if luck. The board can be found many places for 35-50USD.
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              SEMS12 are £3.50+ on Ali, I guess it depends on the OPs tools/skills, worth replacing before buying a mainboard.
                              • 964758
                                • Jul 2017
                                • 40
                                • Georgia
                                Thanks for reply ! I'm agree.
                                • DynaxSC
                                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                  by DynaxSC
                                  Hi
                                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                  08-04-2025, 12:20 PM
                                • tranquility
                                  Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                  by tranquility
                                  i want to repair an Onkyo TX-NR809 receiver.
                                  symptoms:
                                  on power on, display appears and i hear one click. enue functions is given.
                                  - no hdmi output
                                  - audio output not tested, but i think it is not there
                                  - usb sticks are not recognized
                                  if i read out the chips with display+standby button + tone+
                                  both dts show only ????
                                  chip is D830K013BZKB4
                                  things i have done:
                                  - reflow of the dts chip without taking off and reballing
                                  - changed the aluminium caps without the big one with 25v because i dont...
                                  08-25-2025, 01:04 AM
                                • e-repair
                                  Chip identification on hp omen 17cb1008tx
                                  by e-repair
                                  Hello !
                                  i have an to repair an hp omen 17cb1008tx.
                                  i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
                                  can you help me find a reference for this ic ?...
                                  09-23-2025, 03:38 AM
                                  by SMDFlea
                                  Bad...
                                  09-02-2021, 04:40 PM
                                • BMCappelletti
                                  Asus Chromebox CN62 - wrong chip put on BIOS reader
                                  by BMCappelletti
                                  Long story short:
                                  - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                  - gave the computer to his son a couple years later
                                  - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                  - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                  (seems like the story was not that short)
                                  He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                  01-08-2025, 07:27 PM
