Transistor-only colour TV sets
  • japlytic
    • Oct 2005
    • 2086
    Colour TV broadcasting started in the US in 1953, and in 1960 in Japan.
    There were some valve/tube colour TV sets from RCA, including the RCA CTC4 and CTC5 chassis. Their circuits show it is possible to make a valve colour TV set, so it should be possible to make a transistor-only colour TV set (no ICs or hybrid modules).
    I am curious if there were any transistor-only (with no ICs or hybrid modules) colour TV sets (most likely to be American or Japanese sets).
    If anyone has information on transistor-only colour TV sets, please list such sets here!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Transistor-only colour TV sets
    i remember many tv designs with no i.c's in them.
    seems the first one i saw was a sanyo or mitsubishi.
    and btw i am rebuilding a ctc2 chassis.yes the 15gp22 is good.
    • Wizard
      • Mar 2008
      • 2296
      Yes, I have worked on very few TVs that were from transistor era. Remember, back then the most transistors couldn't handle high MHz (RF stuff) so many make kept using glass tube and metal tiny tube on tuners till early 80's.
      Keep in mind, germinum transistors was used till 65-66 even bit later then silicon took over quick but specifications was not as refined till 70's. But transistors made huge simpifications on the circuit part count vs tube and current demand dropped and efficienty went up.
      At my work is 27" JVC CRT with all the newest stuff stuffed in it only sip 105W and does have component input.
      But late model 3 CRTs with ICs and flyback transformer THUMPS LCD and DLP in that size on energy efficienty like RCA D52Wxx models (52") that only need 230W and slightly few watts more on 61" models. I'm speaking of 2002-2006 models.
      That took years till 2006 that Samsung came out with LED DLP that bought down to 56" with 230W instead of higher watts like 250 or more watts. LCDs larger than 22" with CCFL can't match, neither the Plasma panels. Future goes to the LED as light source and OLED, SED and efficient panels.
      "green wattage" LCDs with CCFL is good to around 22" and from there, watts goes up dramatically. My 19" samsung is around 30-45W vs 17" CRT that LCD replaced was 80W.
      Honestly best performing with blackest blacks goes to CRT, LED DLP and OLED, SED etc. Plasma can't compete either because of the slight glow due to current to keep cells at the "trigger point" for fast response, hence the tinted glass in front of panel, to get some contrast at expense of brightness levels, but that also shortens the plasma panel life. And LCD backlight had to do extreme lumens to provide reasonable brightness AT expense of black levels and diffcult to keep those glow, beamlights and light "hot spots" to a minimum.
      Cheers, Wizard
      • DCJack
        B&K 707 tube tester. I need help.
        by DCJack
        Hi everyone!
        I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
        Initially I noticed that I was not getting the red on-light to turn on, but it...
        03-05-2024, 05:05 PM
        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire ā€œLā€ to...
        04-09-2023, 08:04 PM
      • AJ847.63e
        BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
        by AJ847.63e
        Hi All.
        Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
        The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
        09-18-2023, 06:42 PM
      • Schoenradt
        ECH81/6AJ8 Vacuum Tube Question
        by Schoenradt
        Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
        06-10-2021, 05:49 PM
      • porfyriadhs
        Samsung UE32EH4000W Colour problem
        by porfyriadhs
        Hello dear friends. I have problem with a Samsung UE32EH4000W. The tv starts with good Colour quality and after a while the colour changes. Anyone can help me please
        06-25-2024, 01:21 AM
