Element ELCHW402 - Screen Does Not Turn On
    Re: Element ELCHW402 - Screen Does Not Turn On
    They are normal, but how about the 24V at the connector that goes to the inverter board?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Originally posted by jjl4999
      I purchased two like kind replacement capacitors and recorded the following results:
      C812 measured 4.48 uF out of circuit.
      C811 measured 4.75 uF out of circuit.
      Both new capacitors measured 11 uF out of circuit.
      I installed the new capacitors at C811 and C812 and first plugged the 1K resistor connecting Standby and 5Vs. I was able to measure around 13V on N811 pin 12 and around 10 V on N811 pin 12, all referenced to negative of C810. Voltages were in the acceptable range listed in Dick's document. I then connected all of the boards to the main power board, pressed the TV Power button, and recorded the following results at the cold side connector when referenced to the chassis:
      STB: 2.16 V
      5V_S (#1): 4.94 V
      5V_S (#2): 4.94 V
      12V (#1): 11.99 V
      12V (#2): 11.99 V
      BR1: 2.84 V
      5V_M (#1): 5.27 V
      5V_M (#2): 5.27 V
      SW: 3.02
      These values seemed normal so I picked up the TV and saw the blue screen with no signal message. I connected an antennae and have the TV powered on and working for the past few hours.
      Thanks to everyone for the knowledge and information. I enjoyed the whole process. My first successful electronics repair.
      I have to admit that I would not have guessed changing out C811 and C812 would have solved the issue. Any tips on how to become better at troubleshooting power boards and following schematics?
      Stay an active member of the forum and follow how other faults are tackled.
      • jjl4999
        • Mar 2017
        • 21
        I measured 24.7 volts out to the inverter board across all terminals labeled 24V on the connector.
        • jjl4999
          • Mar 2017
          • 21
          Will do Dick.
            Glad it is working.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • JunkmanJimbo
              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
              by JunkmanJimbo
              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
              No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
              Please help. Thanks in advance!
              08-12-2025, 11:45 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • andrestecno
              ASUS X201e - The screen does not turn on and remains black
              by andrestecno
              I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
              If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
              Thanks in advance!
              07-18-2024, 07:14 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
