Sony XBR75X850C won't power on, no LEDs
  • brucetv
    • May 2015
    • 281
    • united states
    Re: Sony XBR75X850C won't power on, no LEDs
    Unplug Tv. Remove all hdmi and usb from tv. Then push volume down and power button at same time on the tv, then plug it in and keep holding those buttons until you see the light turn white, then solid green. Sometimes it takes 60-90 seconds. Once you get the solid green insert a USB memory stick with the latest software installed on it and re-install the software. Follow the instructions and remove usb stick when it prompts to do so. If that doesn't work this model also has a history of bad backlights.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • PopsCaps
      Sony Bravia KDL-40V2500 that will not power on
      by PopsCaps
      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
      I do not hear any sound and I cannot see any backlight.
      I have tried disconnecting every cable on each board one at a time to see if anything changes.
      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
      03-25-2025, 11:23 AM
      03-31-2024, 02:12 PM
