I have a LG 55UF6450-UA that when I turn it on it is just a white screen that does not show any menu or volume text on the screen and is unresponsive to remote commands except power on and power off. What are some things that I should test to try to narrow down the problem?
LG 55UF6450-UA with white screen
Tags: None
Re: LG 55UF6450-UA with white screen
Also to clarify and update after further testing... It is a dim lit screen when I turn it on, not a bright white (1st picture). When I unplug one side of the T-Con it gets bright white on one side (2nd and 3rd pictures). Also I have been able to get volume coming out of the TV from an input. I think that this might mean a bad T-con? Is that correct?Comment
T-con on the bottom of the TV, you may have liquid damage to the panel, hope not.Comment
I would check voltages on t-con
T-con voltages (typical)
1. Vin (Vcc): 12Vdc or 5Vdc
2. (Vlogic,LCM, Vddd,VCC): 3.3Vdc
3. Vda (Vs, Vsource,VDD, Vdda,Avdd): 14Vdc~20Vdc
4. Vgh (Vgon,VGHR, Von, Vddg): 20Vdc~30Vdc
5. Vgl (Vgoff,VST,VGHF,VGHEVEN, Voff,Veeg): -5Vdc~-7Vdc
6. HVDD about 8v
7. DVDD,VDDC 3.3v, 1.2v
8. VCOM about 28vI assume no responsibility for any stupid suggestions I might post.Comment
Panel dis-assembly. People spray screen cleaner or children spill liquids and they drain down to the tab bonds and eventually eat away the copper tracks that attach to the LCD panel.
If a replacement T-con is cheap enough and the seller has a rather liberal return policy, I would try to replace the T-con before panel tear down.Comment
1. Vin (Vcc): 12Vdc or 5Vdc.
(13.22)
(3.3)
(16.61)
(27.9)
5. Vgl (Vgoff,VST,VGHF,VGHEVEN, Voff,Veeg): -5Vdc~-7Vdc.
(Flashing between -7 & 27)
6. HVDD about 8v.
(8.09)
(can't find...)
8. VCOM about 28vComment
in my notes, i have vcom listed as half of avdd approx.
perhaps someone can clarify this one.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Disconnect the lvds cable.
Connect a wire from 12v on the power supply and solder it to the TCON fuse.
Finally solder a small piece of wire to the vdc test point and connect it to pin 44 on the TCON input.
Turn on the tv.Comment
1) Is the lvds cable the input cable that comes into the topside of the TCON board?
2) I can't find a DC 12V+ source on the power board... Where should I be able to find this at?
3) Last, where is the VDC test point, n the TCON? I can't find it. Also I can't find a pin 44 on the TCON? Any help on location of these would be greatly appreciated.Comment
This may help: https://cdn.badcaps-static.com/pdfs/...d6ef3fc97d.pdfI assume no responsibility for any stupid suggestions I might post.Comment
Does this mean bad Main Board?Comment
It certainly looks like it must be a main board problem. The above test eliminates any panel or Tcon fault since the pictures look good.Willing to help but I'm no expert.Comment
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM - Loading...
