Sony KDL-50W700B _ Amber / Green blinks
  • tw2005
    • Oct 2011
    • 6458
    Sony KDL-50W700B _ Amber / Green blinks.
    I swore I'd never touch a sony but I have.
    Don't know the full story because I've been had a little, could be a bad panel to boot.
    Described as Backlights, sound , no picture.
    get it home, turns on, has half picture which seems perfect, right half, pure white.
    Ok, nice surprise, expect it's a bad T-con. Climb inside and start to notice evidence someone's been in before, get to the TCon and ribbon disconnected from right side.
    Ok, this is not good. Hook it up and I get , Backlights, sound , no picture..
    so I try heat, try freeze and no change except now left side comes on looks ok for a moment and then get some vertical bands mainly green and red.
    Fearing bad panel but I move on.
    get another Tcon (used) but realise it's from an 800B, looks the same.
    But it's not. very close
    Both panels to my knowledge are T500HVF04, could be a revision difference.
    So now with the new tcon, the backlight flashes for an instant and then I get amber/green blinking.
    Read about firmware upgrades after replacement boards, but I can't get it to load / work.
    really don't know what I'm doing .
    So , Sony experts, Is this normal after a board replacement? Is there a workaround? Can a faulty TCon cause it?
    What exactly is this indicating? failed bootup?
    I thought I'd be smart and swap the falsh chp acropss from the original TCon but same problem.
    I've put the original Tcon back turns on , with bad image.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Sony KDL-50W700B _ Amber / Green blinks
    have you had a look at the ceramic caps on the panel driver board and while your there you can give the tabs a poke.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • tw2005
      • Oct 2011
      • 6458
      You mean disassemble the panel frame. No I have not. What am I looking for with the caps?
      Have you had some sony experience? It an AU Optronics panel
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        shorted caps.
        i have done a few tab bond patches and t-can swaps, that is all that i can think of, off of the top of my head.
        • tw2005
          • Oct 2011
          • 6458
          Ok, I have good news and very bad news. To get the TV to fire up with this different tCON, eeprom swap. I did the flash chip but did not recognise a small 8 pin at the input. Swapped that and no more conflict.
          Initially the panel looked perfect, turned it off, hooked up the antenna looked ok then noticed horizontal lines then a dark spot botom right corner which I had not seen before and before you know it the picture was gone and the a glowing red / yellow mess.
          Not knowing much about these but shorted panel I think. Disconnect the right ribbon and what do you know back to perfect left side.
          Tcon is probably getting cooked by the panel. Pity the seller was not more honest about this, probably got screwed themselves. Looks like a parts TV now. get some pics up to amuse some of you
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            doesn't sound good.
            still worth a look over those ceramic caps just in case. you might get lucky.
            • tw2005
              • Oct 2011
              • 6458
              doesn't sound good.
              Maybe, right side is definitely loading the TCON as it's buzzing untill I disconnect it then quiet. Also small blue area like broken panel. Can't see a crack then had a close look at the bezel and i think someone put the wrong bolt in from behind and screwed it into the panel from behind.
              less than 3 years old, would have kept it with all th eapps and wifi etc
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                pull the panel out and look towards a light source. panel crack will become very evident if that is the case.
                • shahnld
                  Sony kdl 65xg9505 green amber blinking
                  by shahnld
                  Good Day.
                  I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                  i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                  green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                  01-03-2024, 03:05 PM
                • iglitare
                  Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                  by iglitare
                  i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                  Backlight seems to work, Sound (Setup menu after reset) works.
                  If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                  Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                  With my small knowledge i would think at least the cables are good.
                  Can this happen because of a bad tcon board?
                  Or is it always a bad/shorted...
                  09-04-2025, 07:13 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • thelankanguy
                  Sony KD-55X9000F TCON Issue
                  by thelankanguy
                  The TV shows a black screen with no image.
                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                  Later both ribbons were disconnected and TCON voltages were tested.
                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                  There is also a short to ground in this circled inductor.
                  Is this a TCON issue or something else ?...
                  12-13-2024, 12:27 AM
                • GoodCapDude
                  Sony XBR-75X940E intermittent 6 blinks error code
                  by GoodCapDude
                  Hi everyone. First post on Badcaps!
                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                  09-20-2025, 06:07 AM
