Sony KDL-50W700B _ Amber / Green blinks.
I swore I'd never touch a sony but I have.
Don't know the full story because I've been had a little, could be a bad panel to boot.
Described as Backlights, sound , no picture.
get it home, turns on, has half picture which seems perfect, right half, pure white.
Ok, nice surprise, expect it's a bad T-con. Climb inside and start to notice evidence someone's been in before, get to the TCon and ribbon disconnected from right side.
Ok, this is not good. Hook it up and I get , Backlights, sound , no picture..
so I try heat, try freeze and no change except now left side comes on looks ok for a moment and then get some vertical bands mainly green and red.
Fearing bad panel but I move on.
get another Tcon (used) but realise it's from an 800B, looks the same.
But it's not. very close
Both panels to my knowledge are T500HVF04, could be a revision difference.
So now with the new tcon, the backlight flashes for an instant and then I get amber/green blinking.
Read about firmware upgrades after replacement boards, but I can't get it to load / work.
really don't know what I'm doing .
So , Sony experts, Is this normal after a board replacement? Is there a workaround? Can a faulty TCon cause it?
What exactly is this indicating? failed bootup?
I thought I'd be smart and swap the falsh chp acropss from the original TCon but same problem.
I've put the original Tcon back turns on , with bad image.
