I have a LG 60" plasma model 60PB6650-UA
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: I have a LG 60" plasma model 60PB6650-UA
    If you screw up and toast your board, PTS won't fix it. If these main boards are that rare, you may want to keep that in mind.
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      Best bet on a rare board for a 60" plasma is PTS Electronics. Excellent quality of service and speed of repair and return. I have used them many times. Never a problem.
      Oh yeah, when you put it back together, tighten all of the board hold down screws on all boards using a normal hand screw driver. You will find many of them quite loose. can cause X and Y sus board damage.
      LJ
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Originally posted by Keith.Russell
        I contacted pts electronics and they want $125 + shipping for me to have it repaired with them any simple way to do this on my own?
        Thanks!
        $135 or so to fix a nice 60" TV doesn't sound too bad to me.
        • stjeff0
          • Jul 2015
          • 11
          Finally got the YSUS and found working driver boards. I'm trying to get Nick @ NicksTV to start repairing these 3 boards. Tried that Oleg guy on the Bayster and he kept my parts!!! Still can't believe that. We got our money back, but I had to scour the net to find 2 more. Won't make that mistake again. TV is working perfect. This is our 3 one this year that needed all 3 boards.
          • EchoEleven
            • Oct 2018
            I know it's a little late on this thread, but you guys really helped me out!! I did the test pattern by jumping the pads, and the tv comes on, does red, green, blue, then swipes all ways with white.. So I am going to guess it's my main board, but was also thinking could it be the logic board? Just curious if someone will answer, I think it's the main board, but not 100%..ANY help will be greatly appreciated!
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
