Sony KDL-55BX520 powers on to green light but no boot
  • keysal
    • May 2013
    • 11
    I have not been able to find a service manual for this TV anywhere on the internet, neither free sites or for pay. It just doesnt seem to exist.
    I came across this video from Coppell TV that shows how to diagnose and repair the power supply APS-311 1-885-143-11.
    https://www.youtube.com/watch?v=1ziLm_yPUQI&t=5s
    I checked the pin voltages and they seem fine. STDBY was 3.5 and the 13V pins were 12.8. I didnt read the 400V capacitor yet because I wasnt sure the proper procedure. Whether between the capacitor legs or from the positive of capacitor to some hot side ground?? avoiding sparks is ideal.
    The main board uses a MediaTek MT5388 SOC in a BGA package that gets hot as a pistol when plugged in and on. It seems to turn on automatically If I disconnect the keypad and I have been able to get the back light to come on and once it even showed a "no signal on HDMI 2" on the screen but without the keypad attached and no remote control I wasnt able to test other connectors like the tuner etc.
    I wanted to see if I could get a video signal to the screen I turned off the tv and hooked up a video camera to that hdmi port but I couldnt get the TV to turn on again with the cable hooked up.
    I noticed Shop jimmy is out of stock of the main board but does have a repair kit for the power supply that involves a fair number of components to replace.
    I'm wondering if there is a way to stress test the power supply to make sure if I need that kit or not.
    I have found other main boards and I figure I should probably go ahead and get one but would like to make sure the power supply won't kill it.
    When I pushed down on the mediatek chip with pliers and added power it turned on back light and it seemed like the chip took longer to get hot which so far has gotten to 80 Celsius range. After power is off it seems to cool off quickly enough. Im tempted to flood BGA with liquid flux and try to reflow to see if maybe some whiskers had formed between solder balls causing a short. I noticed a lot of reballing kits and stencils for this chip type.
    Awesome Girl Friend got me a hot air solder station for birthday and I sure would like to get this TV working to give her in Time for Game of Thrones.
    Any ideas?
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Sony KDL-55BX520 powers on to green light but no boot
    Any ideas?
    i think that you have answered your own question.
    either reflow or reball the bga, or replace the main board and you should be all good.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • jheunne
      A1466 macbook no boot green to orange light help
      by jheunne
      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
      in first image there is 0v out for lcd
      https://ibb.co/5XppmpkH
      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
      https://ibb.co/fdJkbJs8
      06-10-2025, 10:52 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:33 AM
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      01-26-2025, 08:18 AM
    • lcdcaps1
      820-2610-A Sys onewire help, no green light. Please help from the gurus
      by lcdcaps1
      Hi
      I have an 820-2610-A motherboard that has no green light.
      I have noticed is when I do a SMC reset the light on the Magsafe blinks.
      From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
      The sys onewire circuit on this model and others is more involved
      I was hoping if anyone knows about this and how it works, can reply and let me know
      I know this is an old model but I am sure there are people who still works on these or knows about them
      I get 1.1v on the C7771 capacitor and will replace...
      11-06-2023, 01:28 PM
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
