Plasma Displays General Lines Question
  • Michale32086
    • Nov 2011
    • 1453
    I have a general question about horizontal lines in plasma TVs..
    Assuming that the Buffer Boards are good and assuming that the X/Z-SUS is good, would these lines be a display panel issue and, therefore, un-repairable??
    I have 2 Plasma TVs with this problem and I just want to know if I should cut my losses or if it could be a Control Board or Main Board issue...
    Thanx...
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Plasma Displays General Lines Question
    Is this a 'C' series Samsung plasma? This looks like a notorious failure of a Samsung PN50Cxxxxx panel. So common in fact, that it's hard to even sell parts for that panel series because they've all failed.
    • Michale32086
      • Nov 2011
      • 1453
      One of them IS a PN50C... The other one, the one that the pic was from is a PN51D....
      So, it's a pretty safe guess that it's a panel issue??
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • xNOTx
        Verticle lines on Samsung PN42A400 Plasma TV
        by xNOTx
        Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
        [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
        04-30-2024, 04:22 PM
      • afex
        Samsung Plasma TV with vertical lines (model PN50B430P2D)
        by afex
        This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
        This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
        I have attached an image of the TV with these bars displaying....
        11-08-2021, 09:23 PM
      • thetonywarren
        Samsung PN51E450 Plasma Vertical Lines
        by thetonywarren
        Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
        Any help would be appreciated.....Please let me know.......
        02-14-2022, 01:23 PM
      • Syseng
        Lenovo P14s Gen 5 SVP unlock
        by Syseng
        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
        06-22-2025, 07:44 AM
