Verticle lines on Samsung PN42A400 Plasma TV
  • xNOTx
    • Apr 2024
    Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
    [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    It's not a board. Generally unfixable thing as far as I'm aware. Sometimes you can push on a cof cable and it'll make it disappear
    • xNOTx
      • Apr 2024
      Yup I've tried touching them, moving them, re-seating and cleaning. I'm thinking there is another cause, and not an issue with the screen. But I could be wrong.
      Weird thing is that it looks like they are both at the same distance from the side of the screen. Also they look like they are between pixels.
      Oh, is it possible to swap boards with different revisions? IE: LJ92-01485A <-- B, C etc
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        I'm telling you, swapping a board isn't going to fix this. This is a panel defect. But who knows
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          spray freezing air on the bottom ribbon cable next to the bad line.. you can.also try hot air.. not.a.fix, its a test...
            09-07-2024, 05:50 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            Sadly it has vertical lines at the left and one line in the middle-right.
            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
            I have factory resetted the TV as well but also with no luck.
            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • afex
            Samsung Plasma TV with vertical lines (model PN50B430P2D)
            by afex
            This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
            This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
            I have attached an image of the TV with these bars displaying....
            11-08-2021, 09:23 PM
          • thetonywarren
            Samsung PN51E450 Plasma Vertical Lines
            by thetonywarren
            Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
            Any help would be appreciated.....Please let me know.......
            02-14-2022, 01:23 PM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
