LGLN575s-ZE backlight
+ More Options
Posts
  • chrle
    • Sep 2013
    • 158
    • slovakia
    hello,I buy this tv with no backlight,ordered leds from ebay,change burned leds,
    tv power on with dark spots ,on screen,all led are working.
    tv is powered 5 minutes then shut down and no backlight again,leds burned again.
    what cause led to burn ?
    wrong leds ?
    Re: LGLN575s-ZE backlight
    Do you have the specification of the replacement LEDs?
    So the replacement LEDs failed again or the other original LEDs failed?
    We need more details and pictures.
    • chrle
      • Sep 2013
      • 158
      • slovakia
      leds ---> LATWT470RELZK
      ordered from ebay ,ordered for 6916L-1214A backlight strip.
      will post pictures when I change leds
      • dskall
        • Oct 2016
        • 2905
        • usa
        Sounds like you did not replace all bad leds.
        • chrle
          • Sep 2013
          • 158
          • slovakia
          OK burned leds are changed,with new.all were different big leds.
          now backlight not turning off and not burning
          but I have problem when I put filters back (look on picture).
          • chrle
            • Sep 2013
            • 158
            • slovakia
            and changed led are little different colour
              What are those small black ring on the LED's LENS?
              https://www.badcaps.net/forum/attach...5&d=1498750427
              BTW, make sure to go into on screen setup and turn down the Backlights level (not Brightness) as low as possible, that will extend the life of the LEDs.
              • chrle
                • Sep 2013
                • 158
                • slovakia
                I changed plastic led lens from another LG tv.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Those are not correct color. Also care must be taken to center lens over led
                  • chrle
                    • Sep 2013
                    • 158
                    • slovakia
                    this is now my big problem
                    • chrle
                      • Sep 2013
                      • 158
                      • slovakia
                      omg,yes now I need to take down lenses and center over led,and find what colour are original leds
                      • chrle
                        • Sep 2013
                        • 158
                        • slovakia
                        ok what to use to glue led lens?it is very difficult to center lens.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          I apply power to led. Makes it easy to center. Looking straight down no bright light coming out. I am still experimenting with glue
                          • zomi
                            • Nov 2011
                            • 506
                            try flexible superglue
                            • tvsteve2
                              • Aug 2014
                              • 25
                              • usa
                              Locktite makes a supergel in a plastic bottle that you squeeze two blue side bars to dispense the glue. Also the old glue spots need scraped off smooth and the lenses put on level.
                              • triplefour
                                by triplefour
                                09-13-2023, 10:43 PM
                              • hollox123
                                ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                by hollox123
                                Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                1. Laptop keyboard doesn't work
                                2. The backlight on the laptop keyboard doesn't work
                                3. The x2 side LEDs (red) on the laptop don't work
                                The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                But I am strongly aiming that it is somehow a BIOS-related problem,...
                                05-11-2025, 08:05 AM
                              • signal.quest
                                Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                by signal.quest
                                I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                03-17-2024, 10:14 AM
                              • DanPoka
                                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                by DanPoka
                                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                02-15-2025, 05:05 AM
                              • Comp_Pro
                                No Backlight Macbook A1990 820-01041
                                by Comp_Pro
                                Hello all,
                                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                Tests performed:
                                There is no backlight even with a good screen.
                                Backlight IC is receiving the correct support voltages.
                                Fuse F8400 ok
                                Current sense resistor R8400 ok
                                Backlight IC is receiving 3.3V on enable pin.
                                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                Backlight IC receiving 5V from PP5V_G3S
                                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                05-06-2024, 10:23 PM
