DVR not booting, stuck on logo screen (Navaio NAV-C08SE)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Not sure whether someone will actually be able to help me, but another man's opinion never hurts. The issue is "simple" got this piece of junk DVR which doesn't boot - it just gets stuck on the logo screen. Mine goes by the brand name "Navaio", although I'm sure it's just generic and other DVRs use this exact same board, especially since I've seen that H.264 splash screen before. I could not find anything on this particular model, hence my low expectations here as well, though perhaps by looking at the board, someone will go "oh, this looks similar to *this* one - try it"....perhaps :| I see a UART connector on the board, but I don't know what to do with it and IF it can be used for this purpose at all. The main issue at the moment is obtaining something that can be written to the thing...anything Cheers.
    Wattevah...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: DVR not booting, stuck on logo screen (Navaio NAV-C08SE)
    There appears to be a couple of step down converters on one of the boards, an MP1482DS and the other one I can't read the number but may be worth checking the output voltages of each. There are also some standard 3 pin regulators on the boards that do have voltage test points. Have you checked those.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Have you tried a different PSU?
      Follow the white rabbit.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Yes of course Definitely bricked....
        Wattevah...
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Is this with no HDD or an HDD connected?
          EDIT: Is that a CMOS coin cell holder? If so, is it populated?
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            No HDD and nothing else attached to the board. I even removed the board from the case. Also, the pictures show the same board, front and back - there's only one.
            Wattevah...
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Many DVRs won't boot with a bad or missing HDD, and some computers wont boot with a missing or dead coin battery. Plug in a FAT formatted HDD and see if it goes.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                I made another discovery: between the 1v test point and ground there's a short, so it could be the CPU is shorted and the splash screen loads from the EEPROM.
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Although I AM getting 1v on that test point.
                  Wattevah...
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • platinumsteel
                    Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                    by platinumsteel
                    Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                    03-18-2024, 05:16 PM
                  • conghuyms
                    MacBook Air A2179 stuck logo , pls help me !
                    by conghuyms
                    Hey everyone,
                    I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                    When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                    I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                    11-05-2025, 08:30 AM
                  • abajor
                    A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                    by abajor
                    Having this very weird issue.
                    The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                    I swapped with a working screen from an A2141 waiting for parts.
                    The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                    The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                    04-27-2024, 01:37 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
