Led tv, diodes for backlight 6916L-1295A
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hello guys, I have Grunding 32'' tv with busted backlight, sound is ok, lcd shows picture under flashlight light... Anyhow, tested the backlight leds, 5 of them are shorted, NC, or producing barely visible light.
    There are 3 led strips marked 94V-0 32"HD Rev 1.0. A1-TYPE 6916L-1295A, can someone tell what kind of bulk leds to buy from ebay, i would prefer leds than complete led strips (price, cough cough).
    Thanks and all the best!
    Re: Led tv, diodes for backlight 6916L-1295A
    What is the model and the maker of the LCD PANEL? SAMSUNG or LG?
    Please upload the Pictures of the LED strip and the LEDs.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Hi budm, panel is made by LG, here are the pics, thanks!!!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need better pictures with lens off. They are probably 2835 3v with anode on the large pad. Here is link that will help http://alpengeist-tvrepair.blogspot....ces-tools.html
          Nice link. I put that link in the TV troubleshooting thread.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I picked it up from another poster here
            • 6ot4hr
              • Oct 2014
              • 87
              • Croatia
              Thanks for the replies guys, i did measure leds for current and voltage. Single led draws 400mA at 3.6V.
              Can you suggest which one to pick in order to replace them...
              Never been replacing them, is there something i should keep an eye on when ordering, except anode/kathode position.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Did you look at link I posted?
                • 6ot4hr
                  • Oct 2014
                  • 87
                  • Croatia
                  Hi dskall,
                  Thanks for helping me with this issue. Yeah, your link was very helpfull, learned me a lot.
                  The diodes i need draw 400mA @ 3.6V when connected to a power supply, the large pad is a + (anode) but i have a few misleads looking at aliexpress. Things that are confusing are:
                  Forward Current (IF ): 400mA
                  Forward Voltage (VF): 3.05-3.65V(250mA)
                  Those are the led info from the aliexpress from your link... Will they draw 400mA or 250mA, thing that confuses me is that 250mA written behind the Forward voltage
                    Did you use current limiter when testing the LED with the power supply?
                    • 6ot4hr
                      • Oct 2014
                      • 87
                      • Croatia
                      Hi Budm, yeah i did, and even with maximum current set on bench power supply
                      (5A) LED still draws 400mA.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        This is were I get mine : https://www.aliexpress.com/item/BY-L...473853104.html
                        • lmcancu
                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                          by lmcancu
                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                          Instead of putting it back together I decided to replace...
                          04-01-2023, 01:11 PM
                        • edugimeno
                          About replacing individual LEDS on BL strips
                          by edugimeno
                          Hi There!
                          Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
                          At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
                          How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
                          11-07-2022, 11:12 AM
                        • Yanleb
                          Vizio M70-D3 4K with dark spots backlight issue
                          by Yanleb
                          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                          03-22-2022, 01:06 AM
                        • Kingfreddie
                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                          by Kingfreddie
                          Ok.. this is the story:
                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                          This is kinda how it looked, just that mine were at the bottom of the screen:
                          09-11-2021, 01:57 AM
                        • canadaboy25
                          LG Flatron 24EN33TA No Backlight When Cold
                          by canadaboy25
                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                          03-07-2023, 12:23 AM
