Led tv, diodes for backlight 6916L-1295A
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hello guys, I have Grunding 32'' tv with busted backlight, sound is ok, lcd shows picture under flashlight light... Anyhow, tested the backlight leds, 5 of them are shorted, NC, or producing barely visible light.
    There are 3 led strips marked 94V-0 32"HD Rev 1.0. A1-TYPE 6916L-1295A, can someone tell what kind of bulk leds to buy from ebay, i would prefer leds than complete led strips (price, cough cough).
    Thanks and all the best!
    Re: Led tv, diodes for backlight 6916L-1295A
    What is the model and the maker of the LCD PANEL? SAMSUNG or LG?
    Please upload the Pictures of the LED strip and the LEDs.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Hi budm, panel is made by LG, here are the pics, thanks!!!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need better pictures with lens off. They are probably 2835 3v with anode on the large pad. Here is link that will help http://alpengeist-tvrepair.blogspot....ces-tools.html
          Nice link. I put that link in the TV troubleshooting thread.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I picked it up from another poster here
            • 6ot4hr
              • Oct 2014
              • 87
              • Croatia
              Thanks for the replies guys, i did measure leds for current and voltage. Single led draws 400mA at 3.6V.
              Can you suggest which one to pick in order to replace them...
              Never been replacing them, is there something i should keep an eye on when ordering, except anode/kathode position.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Did you look at link I posted?
                • 6ot4hr
                  • Oct 2014
                  • 87
                  • Croatia
                  Hi dskall,
                  Thanks for helping me with this issue. Yeah, your link was very helpfull, learned me a lot.
                  The diodes i need draw 400mA @ 3.6V when connected to a power supply, the large pad is a + (anode) but i have a few misleads looking at aliexpress. Things that are confusing are:
                  Forward Current (IF ): 400mA
                  Forward Voltage (VF): 3.05-3.65V(250mA)
                  Those are the led info from the aliexpress from your link... Will they draw 400mA or 250mA, thing that confuses me is that 250mA written behind the Forward voltage
                    Did you use current limiter when testing the LED with the power supply?
                    • 6ot4hr
                      • Oct 2014
                      • 87
                      • Croatia
                      Hi Budm, yeah i did, and even with maximum current set on bench power supply
                      (5A) LED still draws 400mA.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        This is were I get mine : https://www.aliexpress.com/item/BY-L...473853104.html
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • Dvsr
                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                          by Dvsr
                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                          After replacing the caps I started testing out the speaker. It seemed...
                          09-10-2025, 10:20 AM
                        • lmcancu
                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                          by lmcancu
                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                          Instead of putting it back together I decided to replace...
                          04-01-2023, 01:11 PM
                        • caspian
                          What Zener Diodes on a Linear Power Supply
                          by caspian
                          Dear members,
                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                          In addition, I discovered that its zener diodes are defective.
                          I can replace the burned transistors.
                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                          Therefore, I cannot replace the zener diodes.
                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                          no schematics are available...
                          05-26-2025, 12:38 PM
                        • hollox123
                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                          by hollox123
                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                          1. Laptop keyboard doesn't work
                          2. The backlight on the laptop keyboard doesn't work
                          3. The x2 side LEDs (red) on the laptop don't work
                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                          05-11-2025, 08:05 AM
