ok folks i was able to fix this set by replacing a single ceramic 5watt 10ohm resistor at designator R929 , on power supply. Yes a single lousy resistor stopped this giant tv from running the bad one read around 2.5 m ohms when it is supposed to be 10 ohms. Yep thats it a single resistor. Tv is working fine now the original symptoms was when you turn it on it would shut right back off instantly the disply did prime before shutoff.....
LG 60pk750
Re: LG 60pk750
Nice,i already repaired a LG 50PQ30R Y-SUS replacing those resistors,it had no picture,all the voltages but nothing else,in this case 2 resistors were "open",each one in series with SET_UP and SET_DN,and also two failed at Z-SUS,all of them 10 OHMs 2W,i put 10 OHMs 3W back in place,screen lit up just fine.
Re: LG 60pk750
Originally posted by Biruslapio View PostNice,i already repaired a LG 50PQ30R Y-SUS replacing those resistors,it had no picture,all the voltages but nothing else,in this case 2 resistors were "open",each one in series with SET_UP and SET_DN,and also two failed at Z-SUS,all of them 10 OHMs 2W,i put 10 OHMs 3W back in place,screen lit up just fine.
