Need help changing (single board TV) LED Driver's Current ( FB Resistor )
  • Ancient1
    • 275
    • Israel
    Elco (?) 50" Smart TV. Backlight ( BL) issue.
    Single Board : TP.SK708D.PC821
    I bought new BL set . - OK
    Power up : Blip . Protection.
    Led Tester shows current at 34.2 mA , Previously it was 42.1 mA
    Solution : Change current output .
    The BL IC is marked on the photo and datasheet is QOB33535 Datasheet(PDF) - Schneider Electric (alldatasheet.com)
    Calculating according to the datasheet - see attached photo :
    With ILed = 34.2mA , equation #1 is RFb = 400mV / 34.2 = 11.7 Ohm , and with 42.1 mA we get 9.50 Ohm . i.e I should look for 9.5 Ohm R on the FB, pin $5, line . ​
    I need to change 9.5 Ohm to 11.7 Ohm
    But I can not find 9.5 Ohm resistor (array ?)
    I hope someone has a clue .
  • youpla
    PowerColor rx 5700xt dual fan : current sense resistor
    by youpla
    I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
    The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
    The card wasn’t displaying anything after this fix.
    When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
    I tried to resolder it with a hot air station, but the resistor wouldn’t...
    12-01-2025, 07:52 AM
  • Califauna
    Help with boom box modification
    by Califauna
    Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
    I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
    From factory the specs of the boom box are:
    -Power Input: DC 5V
    -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
    -Drivers:
    -2 x Woofer, 70mm, 10Ω, 70mm,15W
    -2 X Tweeter, 8Ω, 30mm,10W x 2
    -Frequency...
    12-04-2021, 01:53 PM
    ISL95836 Laptop PWM Controller Datasheet
    The ISL95836 Pulse Width Modulation (PWM) controller IC
    provides a complete solution for IMVP-7/VR12 compliant
    microprocessor and graphic processor core power supplies. It
    provides the control and protection for two Voltage Regulators
    (VRs). The first VR, typical for Vcore, incorporates 2 integrated
    drivers and can operate in 3-, 2- or 1-phase configurations. The
    second VR, typical for graphics, incorporates 1 integrated
    driver and can operate in 2- or 1-phase configurations. The two
    VRs share...
    11-05-2024, 03:31 PM
    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
    Based on Intersil's Robust Ripple Regulator...
    11-05-2024, 03:24 PM
  • unimatrix93
    Which resistor should I remove/replace to decrease current to backlight leds?
    by unimatrix93
    Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
    However I need some help identifying the resistor I need to replace to achieve this.
    Thank you!
    11-29-2024, 05:05 AM
