Philips 55PFL3907/F7 Sound and Backlight, No Video
  • kdh2012
    • Dec 2012
    • 17
    • usa
    Re: Philips 55PFL3907/F7 Sound and Backlight, No Video
    Well, I jumpered the Uart Tx & Rx signals back to the FRC board (using a 1k res) and it turned on the outputs of that board. There was still no data, but the outputs were live.
    So the FRC board was sending a Uart signal to the Main, but the Main was not communicating back (at least I think so).
    I have ordered a Main. We'll see how it goes.
    • kdh2012
      • Dec 2012
      • 17
      • usa
      Sure enough, the main board did fix it. $100.
      So if your FRC board has good input signals, but no outputs, check the uart, SCL & SDA signals.
      I'm thinking it is firmware, but couldn't update it without a picture. I did try precisely inputting the exact arrow and enters from the remote (copying off the good board), no luck. Just not reasonable to do that blind.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4467
        • Italy - Milan
        I don't understand more my only post, maybe a was wrong.. but there's a possible reason of why, in the tv i've fixed, tcon was supplied by a power line that goes directly PSU>FRC but on FRC stays only to be enabled after FRC initialisation by a transistor network and after it goes to screen, supply voltages for FRC circuits was supplied by flat cable from mainb., since one of you said that supply tensions on FRC are ok, are we so sure of this? i have not read about 12V exiting the mainb. to lvds cable, that 12v is normally switched on by a transistor network on the mainboard. This eventually has to be checked.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Thanks for conformation. So if main board is sending data to frc then it must be lacking the enable to frc chip to turn on. I doubt if enable is routed through transistor. Probably from main chip directly to frc main chip. I may try reflow of main board chip
          • kdh2012
            • Dec 2012
            • 17
            • usa
            I tried a reflow twice - no difference.
            The "enable" from the main to the frc board is not a single signal, as we wish it was. It is a handshaking set of signals. I checked the uart, scl & sda signals. They definitely had continuity all the way to the main IC. But the main never outputted anything on those signals. The frc did output on the uart signal, to the main.
            frustrating ....
            Sorry Davi.p; I don't understand what you are asking.
            edit: I did have 12v going to the tcon board. Just no lvds signals. I have seen fets go bad and not supply the 12v (or 5v) to the tcon. But that was not the problem on my tv. I wish it had been ...
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4467
              • Italy - Milan
              #26
              No, i was asking the presence of the 12v from mainboard to frc through the lvds cable.
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                Well at least we know it is main board problem. I will concentrate efforts there.
                • tumoheat
                  • Jun 2017
                  • 11
                  kdh2012, where did you buy the main board from?
                  • kdh2012
                    • Dec 2012
                    • 17
                    • usa
                    #29
                    I got mine off of ebay. There are cheaper ones for 40" & 46" tv's. I don't know that they will work completely. So, I ponied up the $100 and bought the right one.
                    The p/n that I got was: BA11P4G0401 Z_2_1 Don't know if I needed the "Z" for sure or not. Better safe than sorry.
                    Good luck!
                    • tumoheat
                      • Jun 2017
                      • 11
                      It was on Ebay yesterday but now is sold out. Should have jumped on it. I'll keep watching.
                      Thanks again
                      • Max514
                        Samsung UN55H8000 sound but no backlight no video
                        by Max514
                        Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                        The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                        I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                        • Unplugging the main board cable at the power supply >>> backlights came on.
                        • BLU_ON signal from the
                        04-14-2022, 10:34 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • bohaboha
                        PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                        by bohaboha
                        when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                        Do I disconnect the plug from the power supply, no backlight
                        Thought the backlight would light up when you remove the plug from the power supply but no
                        What could be wrong if both halves work separately?​...
                        03-07-2025, 09:45 AM
                      • gl4709
                        Samsung un55cu7000d with backlight and sound No Video / Picture
                        by gl4709
                        I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                        01-23-2025, 06:21 PM
