Philips 42PFL5332D/37 Chassis EJ3.0U LA Will Not Power On
  • dukie
    Junior Member
    • Feb 2017
    • 32
    Re: Philips 42PFL5332D/37 Chassis EJ3.0U LA Will Not Power On
    after cofirming that i do have 160 vdc across the main caps, does this indicate that the main board could possible be bad also?
      So you do have 160VDC on the main filter cap to run the standby power supply section.
      So then do you get any DCV on any of the pins of the connectors on the cold side of the board?
      • dukie
        Junior Member
        • Feb 2017
        • 32
        no stby voltage (5vdc) on any of the pins on the cold side.
        pin 1 -12 -16v (no dc voltage here)
        pin 2 +12 -16v (no dc voltage here)
        pin 5 +5v stby (no dc voltage here)
        pin 9 +12vs (no dc voltage here)
        • dukie
          Junior Member
          • Feb 2017
          • 32
          hey guys, i cannot for the life of me locate the power IC to check the supply voltage (vcc) pin out. Also, philips had informed me that there is no schematics available for the model tv. i'll keep probing around cautiously. thanks!
          • dukie
            Junior Member
            • Feb 2017
            • 32
            any suggestions out there?
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
            • CurtisC
              Philips 75pfl5704/F7 No sndby power
              by CurtisC
              Hello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
              Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
              The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which...
              04-01-2023, 11:53 PM
