RCA L22HD41 totally dead (fixed)
  • CapLeaker
    Leaking Member
    • 8120
    So got today a small RCA L22HD41 that appears to be totally dead on the bench. No LED, no nothing. After I opened it up there were 5 capacitors on the PSU looking pregnant! Fuses, diodes, Fet, all good. Changed three 25V 680uF, a 16V 1000uF and a 16V 1500uF in the secondary and the puppy is rolling once more!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: RCA L22HD41 totally dead (fixed)
    To easy
    • CapLeaker
      Leaking Member
      • 8120
      waay to easy. ;-)
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        wish i could get some easy ones too.
        share them please. dsk can have the next one.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • CapLeaker
          Leaking Member
          • 8120
          I usually get more stuff, but I don't post everything I have on the bench. It does take time and time is is a rare occurrence these days for me at least. I am sure some have noticed.
          • Mike Russell
            Lenovo 14ALC6 - NMD521 - No power, totally dead.
            by Mike Russell
            Machine won't power on, no power led, no fan spin, completely dead.
            Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
            Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
            VCC 20v
            ACDET 2.8v
            ACDRV 0v (goes to pin 4 gate of AONS32314).
            ACOK 0v
            REGN 6v
            According to datasheet, conditions are correct for ACOK to be high but it is not.
            Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
            12-25-2024, 08:31 AM
          • phantomEVO
            [HELP] 2 Imac 820-2641 TOTALLY DEAD: NO LED/1 LED
            by phantomEVO
            hi to all! please help with 2 imac 21,5 dead...
            i already changed u7700 in both without luck
            u7700 pin 17, 18, 5, 4, 24, 12
            have those voltages in both imac..
            12v, 5v, 5v, 5v, 0,3v, 3,9v
            i have 3V3_S5 (L7710) in one imac (one led) but no 5v on L7750
            NO SHORT ON L7750
            i have not 3V3_S5 (L7710) in the other (no led)
            PLEASE HELP I'M GOING CRAZY!!
            01-25-2024, 01:46 PM
          • phantomEVO
            [help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
            by phantomEVO
            've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
            replaced u5000 with a brand new one now i have
            PPBUS_G3H=8.18
            3V42_G3H=3.42
            3V3_S5 3,3
            no voltage for PP3V3_SUS (no shorts
            on u8020 i have 0v on P3V3SUS_EN no shorts
            0v on R1464 no shorts
            SMC_ADAPTER_EN, 0v
            PM_BATLOW_L, 3,3
            PCH_DSWVRMEN, 0v
            PM_DSW_PWRGD 0,9v​...
            02-26-2024, 10:08 AM
          • pixellegolas
            Lenovo yoga 3 pro, totally dead
            by pixellegolas
            Hi!
            I have this laptop and first let's go through what happened
            Went totally dead, no reaction
            I thought it was the adapter so I bought a new one = nothing happened
            Opened up the laptop and adjusted the battery cable = Started working
            Worked a couple of days and then went totally dead again
            Now nothing works
            I have opened the laptop, removed basically all removable components. It does not start without the battery or harddrive or anything disconnected.
            Testing with voltmeter I can see 5.3V basically...
            09-05-2020, 11:16 AM
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
