LG 49LB5500 LED Backlight Problem..
  • stedmund08
    • Nov 2015
    • 34
    • England
    Hi All,
    So... It's been a while since I was here and it seems all the knowledge I thought I had has gone and I'm totally at a loss (I've been searching all night too). So.. I thought I'd ask here and see if anyone can kick me off and point me in the right direction
    I've got an LG LED TV and the backlight keeps flicking on-and-off. It comes on for a second and then off for 5 and on for a split second and off...
    I've looked around the board and can't see any bulging caps, tried to fiddle with settings etc and got nowhere..
    I'm assuming it's going to be an LED strip but I thought before I rip it to pieces and get down to that I'd try and exhaust any simple tests I could with just the back open..
    So, I've taken some photos (which I hope aren't too terrible) and now I'm at your mercy Where shall I start do you think?
    Excited to be playing around with this stuff again and luckily I don't really watch much TV so this is as much for fun as anything else before I toss the TV out.
    Thanks in advance all!!!!!!!!
    Re: LG 49LB5500 LED Backlight Problem..
    Where are the pictures?
    • stedmund08
      • Nov 2015
      • 34
      • England
      Sorry! Computer froze whilst downloading from my camera.. Take 2! (and hello again )
      • CapLeaker
        Leaking Member
        • 8352
        measure the voltages on each LED string at the power supply. You have 2 strings.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Intermittent Led on these 5V ran Led sets.
          • stedmund08
            • Nov 2015
            • 34
            • England
            Capleaker - That's great, somewhere for me to start!
            Reecey - I'm not sure what that means, are you saying intermittend LEDs are a common fault with this TV?
            Thanks all
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              As there are two strings of LEDs, are both strings flashing on and off at the same time?
              Rich
              Follow me on YouTube
              Learn Electronics Repair
              • vinceroger69
                • Mar 2012
                • 6714
                Thanks all
                There a few threads around where these leds are/can be intermitant and causing this type of issue
                • CapLeaker
                  Leaking Member
                  • 8352
                  Yeah... LED's can fail like that. Once a faulty LED gets hot, it fails, it cools off, then it turns on again. The cycle repeats. Measuring the voltage on the strings, will tell you on which string the problem is, then you have to disassemble the panel and find the bad LED.
                  • stedmund08
                    • Nov 2015
                    • 34
                    • England
                    Cool - what's/where's the best place to test the strings? At the power supply?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      have you got a led tester?
                      • CapLeaker
                        Leaking Member
                        • 8352
                        sure.
                        • stedmund08
                          • Nov 2015
                          • 34
                          • England
                          Vince - no LED tester just a multi-meter... Do I need an LED tester...?
                          • stedmund08
                            • Nov 2015
                            • 34
                            • England
                            Also, can't find the bloody power lead at the moment, hence I've not been able to report any results yet. Doh!
                            • stedmund08
                              • Nov 2015
                              • 34
                              • England
                              Hurrah - found the cable... Now I just need to figure out where/what I'm testing? I assume I take the power supply board off and test the contacts on the rear? Or should I test on the T Con board?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                can you post a good clear picture of the power supply and also picturs of the connectors on it so we can see the printing by them as you should be able too test the led volatges there too prove you do have a issue.Sometimes though you have to strip the lcd panel down so that you can see the leds then power the set on and hopefully you will see the led at fault.
                                • stedmund08
                                  • Nov 2015
                                  • 34
                                  • England
                                  As requested
                                  • stedmund08
                                    • Nov 2015
                                    • 34
                                    • England
                                    Hmm, they still look somewhat blurry on the screen.. Let me know if they're no good.
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      Would have to take some LED backlight supply voltage measurements at start-up and at shutdown. I would just go ahead and replace all the LED strings, if it is cost effective.
                                      • stedmund08
                                        • Nov 2015
                                        • 34
                                        • England
                                        Where do I measure from? The two coils at the bottom?
                                        • Dobrowol
                                          Asus GA402RK keyboard and kb backlight problem
                                          by Dobrowol
                                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                          04-28-2025, 04:30 PM
                                        • ononos
                                          LG M2362DP Backlight problem
                                          by ononos
                                          hello everyone!
                                          As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                                          I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                                          So i decided to try to...
                                          03-12-2023, 05:05 AM
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                        • Honziq
                                          Backlight problem - Asus M3200WU, board Gapal LA-L291p
                                          by Honziq
                                          I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                                          I was repaired many backlights before but this design i will not understand.
                                          For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                                          Can someone explain me please what to do, what to check?
                                          Thanks....
                                          11-20-2024, 01:24 PM
                                        • grbo92
                                          Backlight problem Acer LA-031P
                                          by grbo92
                                          i have one acer Nitro 5 without backlight on my desk.
                                          Mainboard model: LA-L031P GH53Z REV 1B
                                          Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                                          11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                                          Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                                          Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                                          09-09-2024, 03:49 AM
