Backlight problem - Asus M3200WU, board Gapal LA-L291p
  • Honziq
    • May 2014
    • 58
    • Kazaksa
    I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
    I was repaired many backlights before but this design i will not understand.
    For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
    Can someone explain me please what to do, what to check?
    Thanks.
  • Honziq
    • May 2014
    • 58
    • Kazaksa
    +Have those switches something to do with backlight?
    • Honziq
      • May 2014
      • 58
      • Kazaksa
      This capacitors jumps to 79V shortly after power on, then it sloooowly discharges to 19V rail voltage and then its still 19V.
      Im sure it is for backlight, but I can't find a way how it is connected to BL conn. BL conn has 6pins center two is + and 2 + 2 on sides is - to separate strings with common +. But it goes to another layer of board and I can't measure where it leads.
      • Honziq
        • May 2014
        • 58
        • Kazaksa
        Bl conn
        • R_J
          • 9514
          Check if the pins from the backlight connector, connect to the two switches, they do seem to be in the backlight circuit, The voltage going to 79v (boosted voltage) and then dropping to 19v is likely due to no load (open backlights)
          • Honziq
            • May 2014
            • 58
            • Kazaksa
            Thank for your advice.
            That switches leads to this circuit.
            Maybe someone messed with that when changing SSD.
            This computer is designed in way you have to remove motherboard to gain access to SSD.
            This four mosfets will be each for one LED string I think.
            Leds in LCD are not open every string lights up with psu at 44V. But I think it's maybe open somewhere in the mobo.
            I already tried all combinations of switch configuration but none of them worked.
            EDIT: No that mosfets are for 3,3V and 5V rail, there are not backlight related.
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Since the board needs to be removed to install the SSD, review the cables and connectors. It is possible some was connected in the wrong place when reassembling the machine.
              • Honziq
                • May 2014
                • 58
                • Kazaksa
                Thanks for reply, but there is no possible way to connect it wrong, it can be connected only to webcam port, but this is prevented by cable length. Other connectors are different. Its hard for me to find fault on this board, because there are no schematic anywhere and this design is complicated for me.
                Everything from BL connector leads inside board, cant even find where it leads.
                Maybe I can try connect that 100V capacitor + directly to + on BL connector, but I dont think it will be a good idea.
                Or use step-up module from 5V or 19V rail, but it is not clean repair and without original brightness control.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • C152Heavy
                  by C152Heavy
                  Summary for TL-DR readers:
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • DynaxSC
                  ASUS STRIX Z490-F GAMING - No POST, stubborn board
                  by DynaxSC
                  I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                  The situation looks like this:
                  After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                  1. RTC oscillates normally (32.768KHz).
                  07-08-2022, 05:45 AM
                • ShadowAi12
                  ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                  by ShadowAi12
                  I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                  • The board enters a "ready to power on" state after plugging in the PSU.
                  • Pressing the power button increases power draw.
                  • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                  Measurements:
                  (taken after pressing the power button, while the board is attempting to start)
                  • H_SKTOOC#
                  06-11-2025, 01:05 PM
