Jvc lt-40c540
  • viduka
    • Mar 2014
    • 64
    • Scotland
    Jvc lt-40c540
    Can anyone tell me if the software/firmware can be changed on a main board.
    I've got a JVC LT-40C540 with a faulty main board so the TV is stuck in standby.
    I have been unable to source a replacement board specifically for this model so i thought I'd try same board but from another model.
    I now have a working TV but the display is upside down and displays Polaroid when switched on.
    Board is a MSDV3223-ZC01-01. The two boards look identical but obviously its not that easy.
    Any help would be great.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Jvc lt-40c540
    May be able to correct your display through factory menu options and possibly the polaroid but may have to get polaroid remote. If eeprom was not bad you could exchange eeproms
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Re: Jvc lt-40c540
      You need to flash another firmware.
      Or if you still have the bad main board just change the eeprom.
      It might be a 25q64 chip at position U6
      • irsteve90
        • Sep 2017
        Re: Jvc lt-40c540
        Hey Viduka, i hope you are well and that screen is still somewhat problematic for I have an interesting trade for you. I myself have a polaroid t.v of fault, of which requires a working MSDV3223-ZC01-01, like yourself i was unable to get the part, however I did buy the LT-40C540 board (MSDV3255-ZC01-01), and like yours the screen is upside down. Please get back into contact if you're still active.
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
