Bad backlights suspected on Sharp LC-C5255U LCD
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    I'm working on this Sharp 52" LCD (conventionally backlit; not LED) and it has what appears to be at least one dead backlight. It powers on briefly with a blank screen, then shuts off with a blinking green light. In the time that it is on, I can see a horizontal area that is dimmer than the rest, so I'm pretty sure that this is a bad backlight issue.
    The trouble is, I can't find replacements anywhere for this model. Is there any way to find out what kind of backlight it needs without tearing the whole thing apart? If not, is there an easy way to bypass the system and rig it up to run with one less lamp?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Bad backlights suspected on Sharp LC-C5255U LCD
    You could replace with a zener, but it would be easier to just replace the led
      What is the LCD panel number? You may be able to get the CCFL or they may be EEFL from CCFLWAREHOUSE.
      • dskall
        • Oct 2016
        • 2905
        • usa
        My mistake. Missed that it wasn't led. Here's a video and example of bypassing a tube. Not for your set but may work.
        https://www.youtube.com/watch?v=Dh01ZepjDp0
          Bypassing in that Samsung or SONY only works if the lamps are driven by the Balancer circuit.
          Similar to this one.
          https://www.youtube.com/watch?v=oE6K4xBVweA
          • SurrealMustard
            • Jan 2015
            • 486
            More details about this model; backlights replacement or bypass feasible?
            I finally got the rear cover off and got a look at (as well as pictures of) the layout. There are two inverter boards on the right side and none on the left. The Runtka478wjzz inverter that this model uses appears to actually be for a Sharp panel (not just a Sharp-branded television). No sticker is obviously visible identifying the exact model of the panel, so I'm not sure how to find out what kind of lamps this thing needs (the sticker might be hidden under something though, so I'll try to keep an eye out).
            If I'm reading the markings correctly, these inverters have number 2874025500 transformers on them.
            Beside lamp replacement, the other question is, is there an easy way to bypass one of these in order to allow it to continue to operate without trying to run the defective backlight?
            • dskall
              • Oct 2016
              • 2905
              • usa
              It's possible one of the tubes came out of the socket and you would only have to reconnect
              • SurrealMustard
                • Jan 2015
                • 486
                Socket reconnection q
                By re-seating the inverter board?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  If you are willing I could go through the process to convert your CCFL backlit TV to a LED backlit TV.....I am doing so currently with a LG 42in....I did it 5 times already but with 32in screens without callback.......
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    andrew, i think a lot of us would like to see a thread on this. would be very handy to know how to do this conversion.
                    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                    • SurrealMustard
                      • Jan 2015
                      • 486
                      Cool idea, but is the transfomer bypass feasible on this one?
                      That sounds very interesting and while I would love to see what that process looks like, this particular Sharp isn't mine and I'm on a bit of a time cruch to get it sorted, so I was hoping that somebody had a suggestion for the "easy fix," bypassing the transformer for the downed lamp. Any ideas for how to do it on this particular inverter?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        If it's a tube fault then they appear to be available from
                        http://hdtvparts.net/products/3169-l...2d85u-lc-.aspx
                        • culcuhain
                          • May 2016
                          • 186
                          • U$@
                          Also one of those inverters might have failed. You might be able to just find the wrong inverter, replace it and be good. I did this on a 32" I had. $7 for the part and tv was back in business.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            I'll format a document and post it for review, soon.
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              awesome, looking forward to it.
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                pic of the inverter board please.
                                have you checked the output windings on the transformers yet?
                                • SurrealMustard
                                  • Jan 2015
                                  • 486
                                  I'd like to; how?
                                  I haven't yet. Any advice on how to do so?
                                  • attainteddragon
                                    • Apr 2013
                                    • 764
                                    • australia
                                    measure the resistance on the output pins of each transformer.
                                    i havn't had to look at this type, but looks like one transformer per ccfl.
                                    power off of course.
                                    the one that relates to your non illuminated ccfl may of failed.
                                    if it has, it will have a noticeable difference of resistance compared to the others on the inverter board.
                                    if so, you can replace it and have the tv fully functioning without any bypassing needed.
                                    • SurrealMustard
                                      • Jan 2015
                                      • 486
                                      Infinite resistance!
                                      I'm getting infinite resistance on all of the transformers when testing those output pins with the multimeter. It's not an auto-ranging meter, but I've gone to each transformer and ratcheted through all of the different resistance testing options to no avail. Am I doing something wrong?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Pinout of transformer
                                        • Mustang67ford
                                          Sharp LC-50LB370U PS or backlights?
                                          by Mustang67ford
                                          Hello all. Working on a sharp LC-50LB370U. A few days ago, I turned the tv on and immediately left the room, came back in and tv was black. Turned it off then on and all good (didnt think much of it at the time) for about a week. Did the same thing again but stayed black this time. When turning on, the word "sharp" is dimmer than normal I think then tv goes black. I do have sound and do have a display with the flashlight test. I trided unplugging and also holding in the power button for 30 sec, no change. I opened the back up and the backlights do turn on to some extent for a moment...
                                          11-12-2022, 08:32 AM
                                        • NasTech
                                          Sharp Roku LC55LBU591U No Video but Backlights and Audio ok
                                          by NasTech
                                          Television don't display video but the backlights/Audio works.
                                          I disconnected one side of the T-Conn cable and got distorted video on one side of the Panel. I taped off a few pins on the T-Conn cable both side of the panel displays but distorted video. I also replaced the T-con board results same blank screen. Any suggestions?...
                                          09-26-2021, 11:18 PM
                                        • Tecc1229
                                          Sharp LC- 58Q620U - Standby Light, No Backlights or Image
                                          by Tecc1229
                                          Hello, I have a Sharp LC- 58Q620U 58" LED 4K TV.
                                          When you initially plug the TV into the 120V outlet, I get the initial standby red LED light. After you press the power button the red LED goes out and no other lights come. There is no backlight flash, nor image on screen. No audio with HDMI source plugged in, nor does my laptop detect another monitor plugged in. T-con board makes a clicking sound with or without LVDS cables hookup or off.
                                          My first thought was that it had a faulty PSU. Reading voltages, I was getting a swinging voltages from the DC output from the...
                                          09-17-2021, 10:50 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • bpcannan
                                          VIZIO M557-G0: Backlights or ???
                                          by bpcannan
                                          'Morning,
                                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                          10-29-2023, 06:36 AM
