LG 60LB7100 screen goes black seconds after start up
  • tstew
    • May 2017
    • 21
    Re: LG 60LB7100 screen goes black seconds after start up
    I'm guessing nobody else has any ideas?
      Can you leave the black probe on the chassis, and read probe on the connector P201 pin 4 (P-DIM) to see what DCV you have when the Bakclights come on for seconds? Notes: to get to the EVEN pins of the connector you will have to get to the bottom side of the board or through the wire entrance of the connector, you can get to all the ODD pins on the top side of the board.
      Do the same on P-DIM2 pin.
      • kudalski
        • Jun 2012
        • 12
        Problem is not coming from either of the boards. Main board tested in another TV and it works perfect. power supply board replaced twice...same problem existed unless both power supply board that I got from eBay have this problem. I doubt it.
        I took the screen apart and all light work and look healthy for the 10 seconds they come on.
        Tried disconnecting one of the LED strips to act an open LED the set only gave me about 3 seconds of LED illumination the cut off. That tells me LED current flow sensing circuit is working accordingly.
        Its a damn weird ass problem! if anyone got any suggestion please post. Thank you.
        • kudalski
          • Jun 2012
          • 12
          Went back one more time into the LED's and found the 2 upper strips tend to go out. going to replace then will come back and update
          • kudalski
            • Jun 2012
            • 12
            Problem solved.
            Weak or going out one of the LED Strips. Changed (replaced one surface mount LED on one of the strips). Set is perfectly fine now.
            • Louie728
              • Jun 2017
              • 5
              • Dade
              #46
              Hey All I am having this same issue. The tv comes on show the picture bright for a few seconds then all goes black, sound is ok but it appears like no picture. If I take a flash light and shine on the TV I can see that the picture is there. I assume that it is the LED strips. I am by no means an expert but really woulk like to be able to replace myself if possible. Is this something that I could do? shopjimmy is out of stock on https://www.shopjimmy.com/lg-6916l-1...-12-strips.htm but it appears that I can get here http://www.tvpartscentral.com/lg-691...ips-12-strips/ .. Any help greatly appreciated.
              • dskall
                • Oct 2016
                • 2905
                • usa
                #47
                Youtube has lots of videos on replacing backlights
                • kudalski
                  • Jun 2012
                  • 12
                  I'd say you'd have to be a bit advanced to do this. I been fixing TV's and computers since 1993.
                  You got to be very careful you can easily crack the screen taking it a part.
                  Once the screen is off you can turn the TV on and quickly look see which of the LED's is out. See the strip part # look and order it eBay or shopjimmy.
                  If you want to get more technical then replace the actual defective LED. Clip the LED lens of it, replacing actual LED requires some carful soldering skills (plastic tiny LED burns easily with excessive heat).
                  Once LED replaced and all LED's work and TV stays on what I would do is put back the LED lens using epoxy glue, line it up so the light is spread out or (you will see a shadow of light in the picture when done). Wait a few minuets for epoxy to dry
                  Reassemble TV.
                  • Louie728
                    • Jun 2017
                    • 5
                    • Dade
                    #49
                    Thanks for the reply guys. I am just going to replace all 12 strips ..
                    I would say Im not total novice so I think I will be ok. To make sure I wont screw up the screen im gonna use this disassemble method
                    https://www.youtube.com/watch?v=5rwLDxKgZIA
                      That looks easy but sometime that glass LCD panel get stuck to the rubber cushion strips on the black plastic frame. Just take your times is the key.
                      Also re-solder the connector SMD pins that links the LED strip together, it comes loose from the board every easily.
                      • Louie728
                        • Jun 2017
                        • 5
                        • Dade
                        #51
                        Thanks for your help guys. I ordered the whole array and only needed to replace one strip (determined by turning on while disassembled and I could tell the failing led). The whole job took about 2 hours because I took my time. TV is working fine now. I will probably keep 2 a strips and 2 b strips and put the rest on eBay.
                        • Louie728
                          • Jun 2017
                          • 5
                          • Dade
                          #52
                          I had to do this again on another LED strip. This time I reassembled and there are lines down the middle of the tv and horizontal on the bottom. the lines move also if you move the tv. I didnt have time to take apart agai last night. Did I break something? Did I not assemble correctly? Im just wondering if I should waste my time.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #53
                            Check the LVDS cable(s) from the Tcon to the panel very carefully and check that the fine gold contacts on the cable are not damaged, which can happen very easily.
                            • Louie728
                              • Jun 2017
                              • 5
                              • Dade
                              #54
                              if the cable is damaged. is this replaceable? Worth it?
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #55
                                They are replaceable but I don't know what it would cost.
                                • Tws
                                  I'm having the same problem with same TV. My voltages are led=82v off=55 v. Vc_1=35v off=14.30v. Vc_2=28v off=4.6. vc_3=13v off=11.5v. Vc_4=13 off=11.5. vc_5=13.5 off=11.5. vc_6=13.5 off=11.5. any info would be greatly appreciated. Thanks
                                  • HTR-Informatique
                                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                    by HTR-Informatique
                                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                    I also changed the screen because the PC fell and the screen was broken.
                                    I changed the battery with a new and original battery.
                                    I also had corrosion/oxidation on the...
                                    02-09-2025, 06:51 AM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • VcemPzd
                                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                    by VcemPzd
                                    Hello everyone !
                                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                    04-28-2025, 10:14 AM
                                  • DaniK
                                    Acer Aspire E5-574-52RH - black screen
                                    by DaniK
                                    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                    Symptoms are:
                                    - random black screen after displaying Acer logo...
                                    02-21-2024, 06:27 AM
                                  • turmix
                                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                    by turmix
                                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                    During another reassembly, I made a mistake, and...
                                    01-29-2024, 03:48 AM
