LG 60LB7100 screen goes black seconds after start up
  • tstew
    • May 2017
    • 21
    Re: LG 60LB7100 screen goes black seconds after start up
    LED+78.6 all the VC we're the same as before.
    • tstew
      • May 2017
      • 21
      budm I did leave the meter ground to the chassis and put the positive to each positive side of both LED+ VC+. I'm kinda thinking the back lights are good. Uncertain though. Waiting for your knowledge on this.
        Do you mean VC_X (I.E. VC_1, VC_2,....VC_6). I cannot see how you ca have VC_x higher than the feeding Voltage (LED+).
        • sean0118
          • Jun 2016
          • 103
          Are you sure that the multimeter is working and the DC voltage setting is selected?
          If your unsure, confirm by measuring the voltage of a 9V battery or similar.
          • tstew
            • May 2017
            • 21
            I tested the meter on my truck battery and got 12.2 so I believe I have the correct setting. The LED+ and all the VC 1-6 were at 78.6 on start up.
            • sean0118
              • Jun 2016
              • 103
              These two pins for LED+ and LED-?
              I'm just looking through the thread again to try to understand, what do you mean by LED-? I can't see anything with the label, or do you mean GND?
              • sean0118
                • Jun 2016
                • 103
                I've attached a circuit based on budm's description (I might be wrong).
                Each LED represent 100 or so in series, so the voltage at VC_1 is LED+ minus the voltage drop over the first string of LEDs. So it must be less than LED+ unless something is horribly wrong...
                • tstew
                  • May 2017
                  • 21
                  Here's a picture of the meter setting I'm using and the other picture is from the old board but shows where I tested the LED+ and the plug to the left I tested all 1-6 VC's positive. Results were LED+ 78.7v and 55.8v after the lights were off. All 1-6 VC were the same 78.6v down to 55.9v. Maybe I'm testing the wrong spots for VC?
                    Where did you put the black probe of the meter?
                    • tstew
                      • May 2017
                      • 21
                      I kept it in a screw hole right above the board. I'm assuming it's the chassis. The screw hole is in the big sheet metal backing of the screen that all boards attach to.
                      • tstew
                        • May 2017
                        • 21
                        I'm running out of time to send the inverter board back if this isn't a back light problem.
                        • sean0118
                          • Jun 2016
                          • 103
                          Interesting... sounds like you're doing it right. What's the resistance (when OFF) from LED+ to each VC?
                          • tstew
                            • May 2017
                            • 21
                            I tested resistance from LED+ to each VC+ and got 0.00. then I tested LED+ to each VC- and got 46.7 and 46.6 through out all 6 VC's. Maybe I'm testing wrong with meter setting? My experience with anything electrical is mostly from competition car audio and minor computer upgrades. So this is my first go on trying to save an 1,800 dollar TV.
                            • sean0118
                              • Jun 2016
                              • 103
                              I might be missing something, but there is no VC+ and VC-, only VC, which is the cathode voltage of the LEDs. LED+ is the anode voltage. The pins of that 14pin connector alternate between LED+ and each of the six VC lines.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Damn! Seems that LED tvs are no better than CCFL tvs from the Core 2 era.....(also that was the classic bad cap tv era) (2006-2009)
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • tstew
                                  • May 2017
                                  • 21
                                  sean0118. Thank you for explaining that. I had to magnify the picture of my board to see that. I'll be re testing after a while now that I know exactly where to test the VC. I'll post results soon.
                                  • tstew
                                    • May 2017
                                    • 21
                                    LED+ 78.6v down to 55.9v after back lights off.
                                    VC1_13.5v down to 6.0v
                                    VC2_13.1v to 6.0v
                                    VC3_12.1v to 9.3v
                                    VC4_12.9v to 5.7v
                                    VC5_13.0v to 6.0v
                                    VC6_13.0v to 5.9v
                                    Please note that I have no prior experience with testing. Hopefully I had the correct meter setting and test spots this time. I am grateful for everyone who's helping me through this. I tested all of these results twice to make sure they didn't deviate.
                                    • sean0118
                                      • Jun 2016
                                      • 103
                                      Sounds like your on the right track now, but unfortunately I don't know much about this TV, so you'll have to wait for one of the pros to chime in with instructions.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        #39
                                        What voltages do you have on the EL test points
                                        • tstew
                                          • May 2017
                                          • 21
                                          I tested all 12 EL from left to right and the first reading is with back lights on the second reading is 15-20sec after back lights off.
                                          EL62-13.1v to,6.1
                                          EL54-12.9v to 6.1
                                          EL55-13.0v to 5.5
                                          EL64-12.9v to 5.3
                                          EL52-12.9v to 5.4
                                          EL66-12.8v to 5.3
                                          EL65-13.0v to 5.3
                                          EL53-12.9v to 5.3
                                          EL63-13.3v to 5.7
                                          EL50-13.2v to 5.7
                                          EL67-12.0v to 8.8
                                          EL51-12.0v to 8.9
                                          • HTR-Informatique
                                            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                            by HTR-Informatique
                                            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                            I also changed the screen because the PC fell and the screen was broken.
                                            I changed the battery with a new and original battery.
                                            I also had corrosion/oxidation on the...
                                            02-09-2025, 06:51 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
                                          • DaniK
                                            Acer Aspire E5-574-52RH - black screen
                                            by DaniK
                                            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                            Symptoms are:
                                            - random black screen after displaying Acer logo...
                                            02-21-2024, 06:27 AM
                                          • turmix
                                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                            by turmix
                                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                            During another reassembly, I made a mistake, and...
                                            01-29-2024, 03:48 AM
