ID this transistor in KOSS 22" LCD TV/Monitor?
  • Wizard
    • Mar 2008
    • 2296
    Here's this Koss made by generic maker of this 22" LCD TV/monitor with dead lamp inverter board. I was able to detemine this transistor of the pair is kaput.
    Issue is need to identify this one, can't find good answer with google and couldn't ID this logo, as far as I can detemine it does have NPN or N mosfet and this seems to have a diode or zener across C to E or D to S. Set up as dual transistors totem pole drive that drives all 3 transformers for 6 lamp tubes.
    Reason I need to ID these and what it is typically used. So I can substitute them with ones from my junkbox.
    Doesn't have external damper diode or coils at all, just direct drive.
    As far as I can determine this came about with evil tan glue that did conduct and fried the one of the pair transistor, cleaned glue (crumbly) up.
    Here's the pic:
    Cheers, Wizard
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ID this transistor in KOSS 22" LCD TV/Monitor?
    here is the mfr.
    http://www.aosmd.com/web/index.jsp
    • Krankshaft
      • Jan 2007
      • 2328
      Thanks for the site KC.
      I did some hunting on that site here is your datasheet.
      I couldn't direct link it so I uploaded it for you. It's an N channel MOSFET.
      • Wizard
        • Mar 2008
        • 2296
        Awesome! Now I know what this is and that confirms my suspicion that measurements matches what I see for a MOSFET with a diode. Was not sure which zener or a diode.
        What kind of the diode it is used, high speed or ultrafast or deflection horizontal damper diode type of specifications? If I have the info, I can cobble together a working soluton with the spare parts at my shop.
        Cheers, Wizard
        • Wizard
          • Mar 2008
          • 2296
          Success! Like I said, caps were not the problem, it was degraded glue that distorted the waveforms for driving the pair of MOSFETs and blew one. Replaced both with FDD6690A MOSFETs off a scrapped notebook.
          But I have a issue, these pair is 30V rated, while the old ones were 60V. The LCD power is 19V and is fed to the mainboard and this is also goes to the LCD lamp inverter supply.
          So far I have not found the 60V rated N channel MOSFET with damper diode across D-S.
          Ran 5 hours so far with no issues.
          Cheers, Wizard
          • envisionelec
            • Jun 2006
            Cheers, Wizard
            The reason that 60V devices are used is that the D-S voltage in a push-pull or forward converter is twice the input voltage. Your replacements will eventually fail, too.
            Replacement parts like an IRLR-series in DPAK work perfectly, rated at 60V and have a body diode. I use these in all my smaller (<20W) power supplies.
            http://www.digikey.com/scripts/DkSea...ame=IRLR014-ND
            Regards,
            A. Hammett
            • Wizard
              • Mar 2008
              • 2296
              I know that, and that is EXACTLY what I wanted to hear, care to sell two transistors? Or suggest alterative sources in the devices where I could go digging to sub these two?
              All the notebooks and other smaller LCD inverters uses 24-30V rating.
              Oh, have happy new year!
              Cheers, Wizard
              • keepread
                Dell monitor PSU vs Dell laptop PSU
                by keepread
                Hi there!
                Someone gave me their old monitor, it's Dell S2715ht.
                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                10-30-2025, 04:45 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
                Wise Wing F199 19'' LCD monitor - recapped
                by momaka
                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                When I saw the Craigslist post, I wasn't...
                08-24-2020, 10:58 AM
