Broken LED TV? Vizio M50-C1
  • viziotv
    • May 2017
    • 6
    I have a Vizio M50-C1 and initially, saw the back lights turn on but saw nothing on the screen. I went through the process of replacing
    -Power Supply Board
    -T-Con Board
    -Main Board
    Nothing changed. Lastly, I replaced the LED Driver board and I at least now have some type of picture but it still doesn't show picture properly. What am I over looking?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Broken LED TV? Vizio M50-C1
    Put back in your original Main and T-CON Bds. Looks like mis-match in softwares, to me.
    • viziotv
      • May 2017
      • 6
      I feel like an idiot but when you had me look at the t-con board I noticed the 2 t-con ribbon cables weren't secured in to the board. I latched them in and turned back on the TV. I actually saw a fairly OK image but it still was not 100% clear.
      I then matched up the old t-con board and main and received the attached image. I then put in both the new t-con and main, same thing. I then tried to do old main and new t-con, same. I was so close but now can't seem to get back to where I was earlier with seeing any image.
      Attached is what I see now when I turn the TV on. Any ideas?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Did you put ribbon cables in there original positions.
        • viziotv
          • May 2017
          • 6
          Yes this is how the ribbons look now on the t-con
          • viziotv
            • May 2017
            • 6
            Also, I tested the 14 VGA test pins above the left ribbon cable with a DC meter and they all came back as:
            New board - 3.3
            Old board - 2.5
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Those ribbon cables do not look as though they are fully inserted.
              You lift the black plastic tab up carefully with your finger nail and then fully insert the ribbon before closing the black plastic tab back down.
              Do with care and don't use force or the black plastic securing tab could break off.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Don't understand your vga readings. Each one should read different.
                • budwich
                  • Jul 2015
                  • 3097
                  I agree with Dick.... those cables don't look seated properly. They look like someone tried to force them in without "delatching" the clamp down. The corner side "guides" should be further in when properly seated.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    +100 Hope you didn't damage the cables' fingertips that make the connection.
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
