Vizio E701i-A3 no picture or sound, flashing light
  • fadecomic
    • May 2017
    • 5
    I have a 3 year old Vizio E701i-A3 with no picture or sound, and an irregular, dim flashing backlight.
    It seems like this TV comes up here a lot, unfortunately, but I don't see these symptoms. Here are the details:
    • Powers on, shows V logo clearly and normally
    • Starts flashing. There was a horrible buzz noise, but now it's gone
    • Cannot turn off the TV. Must be unplugged
    • No buttons work on tv or remote
    • Here's the weird one: The TV did this once before, but it went away, and the TV worked fine again for about a year. Then we moved it, and it started again.
    It seems like it might be power related, but I'm not sure. I've tried the trick of unplugging and holding power for 30 seconds, to no avail. Can anyone tell me what might be happening?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E701i-A3 no picture or sound, flashing light
    I would make sure all screws are tight securing all your boards.
    • jeremy1976
      • Apr 2017
      • 10
      You have LED backlight strips that are shorted.
      • fadecomic
        • May 2017
        • 5
        Would that cause it to do nothing at all, though, other than dim flashing? There's no sound either (except the brief buzzing).
        The thing that confuses me is that the V logo that appears at startup looks perfectly normal. It's properly lit and clear. I agree it sounds like a short though, since it worked again for a year after "healing" from the first round.
        • fadecomic
          • May 2017
          • 5
          Here is a video of the symptoms from when it was making the sounds. Sorry for the low quality, but it's the best I have right now.
          https://youtu.be/TmHkK3gtCFk
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I'll go with jeremy1976 and suggest backlights failing. When cold they may work and as they heat up (quick process) shut down the PSU and then nothing will work.
            • fadecomic
              • May 2017
              • 5
              Sorry for the terrible video quality. When I say, "I have", I really mean "a friend with no electronics knowledge has". I'll see if he has something that wasn't filmed on a potato.
              • dskall
                • Oct 2016
                • 2905
                • usa
                So backlights are going to cause tv not to turn off or buttons not to work? Have you checked for loose grounding screws on your boards?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  No not at all...these are symptoms of a malfunctioning Main Bd. However, I have seen where the PSU malfunction seem to produce symptoms of a malfunctioning Main Bd. To rule out the PSU the 'self-test' must be applied but on performing a 'self-test' the backlights must remain connected thereby verifying working backlight, too.
                  • budwich
                    • Jul 2015
                    • 3097
                    did you try any of the "unplug cables test" outline in the many threads you read?
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • gavric
                      Vizio M70-C3 Half picture is bad, main board on its last leg?
                      by gavric
                      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                      When tv powers on vizio V logo shows nice on whole screen. picture 1
                      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                      When i click video to start playing picture goes black(like when you change...
                      09-02-2021, 08:55 PM
                    • nbnb
                      Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                      by nbnb
                      I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                      Any idea what is causing the clicking sound? Any easy way to...
                      11-23-2019, 12:03 PM
                    • kca
                      Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                      by kca
                      Hello all ~
                      I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                      This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                      No picture. No sound.
                      I tested all the voltages coming out of the power supply...
                      10-12-2023, 05:23 PM
