Vizio E701i-A3 no picture or sound, flashing light
  • fadecomic
    • May 2017
    • 5
    I have a 3 year old Vizio E701i-A3 with no picture or sound, and an irregular, dim flashing backlight.
    It seems like this TV comes up here a lot, unfortunately, but I don't see these symptoms. Here are the details:
    • Powers on, shows V logo clearly and normally
    • Starts flashing. There was a horrible buzz noise, but now it's gone
    • Cannot turn off the TV. Must be unplugged
    • No buttons work on tv or remote
    • Here's the weird one: The TV did this once before, but it went away, and the TV worked fine again for about a year. Then we moved it, and it started again.
    It seems like it might be power related, but I'm not sure. I've tried the trick of unplugging and holding power for 30 seconds, to no avail. Can anyone tell me what might be happening?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E701i-A3 no picture or sound, flashing light
    I would make sure all screws are tight securing all your boards.
    • jeremy1976
      • Apr 2017
      • 10
      You have LED backlight strips that are shorted.
      • fadecomic
        • May 2017
        • 5
        Would that cause it to do nothing at all, though, other than dim flashing? There's no sound either (except the brief buzzing).
        The thing that confuses me is that the V logo that appears at startup looks perfectly normal. It's properly lit and clear. I agree it sounds like a short though, since it worked again for a year after "healing" from the first round.
        • fadecomic
          • May 2017
          • 5
          Here is a video of the symptoms from when it was making the sounds. Sorry for the low quality, but it's the best I have right now.
          https://youtu.be/TmHkK3gtCFk
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I'll go with jeremy1976 and suggest backlights failing. When cold they may work and as they heat up (quick process) shut down the PSU and then nothing will work.
            • fadecomic
              • May 2017
              • 5
              Sorry for the terrible video quality. When I say, "I have", I really mean "a friend with no electronics knowledge has". I'll see if he has something that wasn't filmed on a potato.
              • dskall
                • Oct 2016
                • 2905
                • usa
                So backlights are going to cause tv not to turn off or buttons not to work? Have you checked for loose grounding screws on your boards?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  No not at all...these are symptoms of a malfunctioning Main Bd. However, I have seen where the PSU malfunction seem to produce symptoms of a malfunctioning Main Bd. To rule out the PSU the 'self-test' must be applied but on performing a 'self-test' the backlights must remain connected thereby verifying working backlight, too.
                  • budwich
                    • Jul 2015
                    • 3097
                    did you try any of the "unplug cables test" outline in the many threads you read?
                    • ggil44
                      Vizio M65-E0 No Picture, No Sound
                      by ggil44
                      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                      09-03-2024, 08:30 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
