LG 50PN650T sound but no picture
  • PowerAmpFreak
    • 982
    • Sweden
    This plasma LG 50PN650T start up with a white screen but goes black after one second.
    VS and VA stays on, sound is OK.
    I need either a service manual or info how to activate logic board test pattern.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 50PN650T sound but no picture
    If my memory serves me correctly, shorting the 2 pads by R51/R52 and with the ribbon cable removed from the mainboard to run the self test.
    • PowerAmpFreak
      • 982
      • Sweden
      Thanks for suggestion. I wasn't sure, so good to have one more!
      • PowerAmpFreak
        • 982
        • Sweden
        I could not get it to enter logic test mode by shorting those pins and removing ribbon from mainboard.
        The green led on logic board flashes in a special pattern possibly indicating a failure.
        So for now I cannot tell if the failure is logic and/or Y-SUS.
        The symptom looks like the classic 50PK650 failure with the open 22R power resistors. In this case, it's not the same chassis nor the same kind of powersupply. And in this set, VA and VS stays on.
        A bad Y-SUS tend to not produce any picture at all, this turns white directly after start-up, but is shut down the moment after.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Since the Va and Vs are constant we could say the PSU is OK. Since the Vs is good then I would think the Y-sus and Z-sus are OK. The Logic Bd in my mind is your fault. Replace the Bd and your set will work again.
          • PowerAmpFreak
            • 982
            • Sweden
            Yes, it points to the logic board. Thanks!
            • PowerAmpFreak
              • 982
              • Sweden
              Logic board replaced, issue remains.
              Could not activate testmode, probably another procedure.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Is it the correct Logic board. I cannot quite read the EBR number from your photo but the last few digits look like 60602
                Spares2Repair list the last digits as 60502
                https://spares2repair.co.uk/lg-50pn6...50r5-60r5-ctrl
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Yes, both P/N match. They both are EBR75760502
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Do you have the other supplies Vsc, -Vy, Z_Bias and is +5V on the Logic board
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Originally posted by dick_barton
                      do you have the other supplies vsc, -vy, z_bias and is +5v on the logic board
                      +10
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        +5V is present on logic. I guess this fault is somewhere on Y-SUS and I will dig into the supplies to see all are up.
                        It seems like Y-SUS itself are turning off due to some protection.
                        • PowerAmpFreak
                          • 982
                          • Sweden
                          Success!
                          I found a shorted UF4006 diode on the YSUS board in the floating supply section.
                          Now works nice again!
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Excellent
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • jchang
                              Samsung UN70NU6900F no picture and no sound
                              by jchang
                              Hi all
                              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                              Symptom:
                              No picture no sound.
                              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                              No sound at all.
                              What I tried:
                              1. I tried unplugging the left or right ribbon...
                              01-09-2023, 06:28 PM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • kca
                              Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                              by kca
                              Hello all ~
                              I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                              This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                              No picture. No sound.
                              I tested all the voltages coming out of the power supply...
                              10-12-2023, 05:23 PM
