LG 42PT250 - TA not turn on
  • maxvalutech
    • 804
    • australia
    Usual problem so checked power board over and all looked OK fuses diodes etc. Voltage on main caps good at 345v. Standby OK but little else. Checked voltages for turn on with meter connected and signals from main aok. No Vs at all and feed is via X so disconnected lead to Y and switched on - voila 201v sot on. Y sus is E52483 and covered in the gooey gunk from manufacturer. Question 1 can I test sus with buffer removed without damage. 2 any known bad components on this board in your experiences. Thanks in advance.
  • maxvalutech
    • 804
    • australia
    Re: LG 42PT250 - TA not turn on
    Can anyone assist here?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      If you did some research youd find the answer out lol
      • maxvalutech
        • 804
        • australia
        Well given a number of recent posts someone on here needs to search for an article on how to keep your mouth shut if nothing worthwhile to say. I have found the search on this site to return too many non relevant posts but do recall one some time ago that suggested ysus could be damaged if buffer not attached. Also seeking any help re this board from people with far more experience of LG plasma model.
        • maxvalutech
          • 804
          • australia
          Pic attached
          • dskall
            • Oct 2016
            • 2905
            • usa
            Have you checked buffer for shorts?
            • maxvalutech
              • 804
              • australia
              Will have to research test method and get back. Did try for VS with buffers removed but no go although protection may then have kicked in.
              • maxvalutech
                • 804
                • australia
                I did do test on buffer by probe on a ysus input connector pin and other pro e run along all the screen output pins - no reaction from mm. Not worked on LG plasma before but have done several Samsung and recall their buffers had test points but nothing marked as such on this buffer. Ysus board in short supply it seems.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  You could disconnect the Y-sus Bd from the PSU and connect a 230Vac light bulb as a load to the PSU connector supplying the Vs voltage to the Y-sus Bd and apply power the light bulb should glow bright, if the PSU is good. You could measure Va to confirm a working PSU.
                  • maxvalutech
                    • 804
                    • australia
                    Andrew F post prompted me to check Va as I didn't do that when it seemed obvious the problem was with Y side board/s. So I disconnect lead X (Z) to Y and test Vs and Va. Surprise now I get nothing with set clicking on off. In frustration I disconnect lead from power board to X and both Vs and Va come up stable at power board connector albeit my meter shows them a few volts over Vs 201 reads 209 and Va 55 reads 58. Back to the drawing board!
                    • Kamranali
                      • May 2018
                      • 10
                      • Malaysia
                      Hi Maxvalutech
                      I have same board problem burn some parts and cannot see the number also
                      I saw your picture att post here may i know the parts number Ey706 and Ey704 please reply thanks
                      • Kamranali
                        • May 2018
                        • 10
                        • Malaysia
                        Please send me the tow transistors number coz my transistors burn and cannot ready the number
                        • maxvalutech
                          • 804
                          • australia
                          Luckily still have this and both appear to be....
                          IRG7IC28U P106D and on bottom line 53 V8
                          Also note a video is on YouTube about replacing these in another model LG
                          • pajdek
                            Lenovo Y700-17ISK turn on and off
                            by pajdek
                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                            09-20-2023, 02:49 AM
                          • RdeveLabs
                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                            by RdeveLabs
                            To all the members here...
                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                            05-05-2025, 04:59 AM
                          • robante15
                            Acer Aspire 4520 won't turn on after reboot
                            by robante15
                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                            If I remove the...
                            04-06-2024, 06:50 PM
                          • masoksian
                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                            by masoksian
                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                            The system does not turn on, there is no post.
                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                            The problem continues in the same way.
                            I tried to turn on the Fn key, nothing came to the screen....
                            02-15-2025, 12:08 PM
                          • Ledgurra
                            MacBook Pro A1425 it doesn't turn on
                            by Ledgurra
                            hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                            thank you all
                            11-09-2025, 06:07 AM
