Guys i got a LC-70LE745U that someone was throwing away so they gave me for free. I had a error code from the tv did research on it found out it was the main. Ordered the main, now i no longer have a error code. GREAT! Now i am not getting any backlight but sharp logo V stays solid (not on the screen). I test the voltages where the led backlight is connected and i am getting 83.2 volts from the 3 positive wires thats connected to the powerboard. I dont know if that is enough to drive those leds. A friend of mine let me borrow his LED tester. I tested each LED wire and im getting the LEDs to power up from there. Im wondering if the PowerBoard is not producing enough voltage to the LEDs. I wonder since the LED tester has voltage regulator everytime i test led wire the voltage drops to roughly 171 each wire. Is that the power that is suppose to be going to each strip? Sorry to sound dumb guys.
Sharp LC-70LE745U No backlight
Re: Sharp LC-70LE745U No backlight
Also on this tv when you remove the back panel you can see the test points for each strip and where the wires get connected. I tested each connection on the strips and it seems to light up each section and the voltage on each strip is 92.2 on the LED tester. Again i dont know if that means anything.
I guess I can throw back the same question, if its an error problem "anywhere" including backlights, shouldn't you be getting a code? :-)
I guess the question would be, are you currently getting any picture / sound? Have you done the "flash light test"?
Of course, the next area of information would be to confirm all the voltages as identified on the various boards (ie. power board, main, tcon)
Lastly, what happens when you do the "disconnect tcon cables" test?Last edited by budwich; 05-03-2017, 02:03 PM.
Yes i did the flash light test and i see nothing. Inhave not tested the voltages yet coming from the main nor did i disconnect the Tcon while the set was on. Let me gove that a try. Thanks guys. I will let you know what i am getting. Sorry to sound nieve but what do you mean the main cap? Thanks again guys
So you are missing more than just backlights.
Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
Format:
Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
1 - XXXXXXX - XXv - XXXv
2 - XXXXXXX - XXXv - XXXv
3 - XXXXXXX - XXXv - XXXv
4 - etc.I assume no responsibility for any stupid suggestions I might post.
