Tc-50u2 sc board toast?
  • jackfish
    • 89
    • canada
    Found s Panasonic plasma at the dump.. cosmetically it look fine..screen look ok..its giving me ten flashes at start up..unplugged sc power and ss power..came back with the 7 blinks error..plugged back ss and came back 7 again..think it's sc board..trying to find a replacement but there in the 200 bucks Canadian zone..any place I can find it cheaper ...thanks to anyone who replies..
  • 2smoovedaddy
    • Aug 2012
    • 42
    Re: Tc-50u2 sc board toast?
    What's the model on the sc board. I have one that might match.
    • 2smoovedaddy
      • Aug 2012
      • 42
      I checked and mine is not a match.
      • jackfish
        • 89
        • canada
        Tnpa5105ab is wgard on the board..
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          Linear Garage Door Opener Control board took a crap install a new control board back normal
          I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
          02-08-2025, 06:52 AM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
