Re: Samsung UN55HU6840 No picture has sound and backlights
Thanks for the info.
So it looks like the Tcon is a 3.3V Tcon. What voltage is on pin 4 when you switch on and when you bring it out of standby?Willing to help but I'm no expert.Comment
Looks like 4485D maybe you can make it out. Had to magnify it to see it.
Voltage on first 4 pins is 12.76 and 0 on the last 4.
Sorry didn't see it had been posted already.Attached Filesif you find these attachements useful please consider making a small donation to the site
OK so it looks as though its a 12V supply to the Tcon. Can you measure the resistance from pins 5,6,7 or 8 to 0V (ground) with the set off and meter set to ohms.
I suspect the chip is blown and is not switching the 12V input at pins 1,2 &3 to output pins 5,6,7 & 8 when Pin 4 goes to 12VWilling to help but I'm no expert.Comment
All open(OL). By the way thanks for all you guys help.Comment
If the resistance on the output pins 5,6,7, & 8 is high then it does not look like a short circuit causing the problem so I suspect the IC to be at fault.Willing to help but I'm no expert.Comment
Will do I'll keep you posted on the results.Comment
by stingerWhen I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by iglitareHi,
Or is it always a bad/shorted... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... - Loading...
