Samsung UN55HU6840 No picture has sound and backlights
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UN55HU6840 No picture has sound and backlights
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Thanks for the info.
      So it looks like the Tcon is a 3.3V Tcon. What voltage is on pin 4 when you switch on and when you bring it out of standby?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Don't see how 55" could run off 3.3v. Looks like maybe trace runs to ic2602? 2802. Also see a 13v panel on legend.
        • 2smoovedaddy
          • Aug 2012
          • 42
          Looks like 4485D maybe you can make it out. Had to magnify it to see it.
          Voltage on first 4 pins is 12.76 and 0 on the last 4.
          Sorry didn't see it had been posted already.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            OK so it looks as though its a 12V supply to the Tcon. Can you measure the resistance from pins 5,6,7 or 8 to 0V (ground) with the set off and meter set to ohms.
            I suspect the chip is blown and is not switching the 12V input at pins 1,2 &3 to output pins 5,6,7 & 8 when Pin 4 goes to 12V
            • 2smoovedaddy
              • Aug 2012
              • 42
              All open(OL). By the way thanks for all you guys help.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                If the resistance on the output pins 5,6,7, & 8 is high then it does not look like a short circuit causing the problem so I suspect the IC to be at fault.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  I would replace it their inexpensive. It's a 4435 P-Channel 30-V MOSFET SOP-8
                  • 2smoovedaddy
                    • Aug 2012
                    • 42
                    Will do I'll keep you posted on the results.
                    • stinger
                      Samsung UN70TU6980FXZA no sound no picture but does have backlights
                      by stinger
                      When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                      04-17-2024, 03:06 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
