Samsung UN55HU6840 No picture has sound and backlights
  • 2smoovedaddy
    • Aug 2012
    • 42
    I got this Samsung pretty cheap and thought it would be an easy fix but I'm getting sound and back lights but no picture. Already tried to to re-seat the cables on the t-con board and detached them one at a time with no success. Also replaced the t-con board(ebay) with no success. Also when I power it up I see the red light flash five times don't know if that's normal. I've attached pics. Any where I can get a manual without having to pay. Went to Samsung website and they're charging for the service manual. Any help would be appreciated. Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UN55HU6840 No picture has sound and backlights
    Make sure you are getting t-con voltages
    T-con voltages (typical)
    1. Vin (Vcc): 12Vdc or 5Vdc
    2. Vdd (Vlogic, Vddd): 3.3Vdc
    3. Vda (Vs, Vsource, Vdda,Avdd): 14Vdc~20Vdc
    4. Vgh (Vgon, Von, Vddg): 20Vdc~30Vdc
    5. Vgl (Vgoff, Voff, Veeg): -5Vdc~-7Vdc
    • 2smoovedaddy
      • Aug 2012
      • 42
      Thanks for the response dskall. I'm getting no voltage in any of those areas of the t-con board.
      • dskall
        • Oct 2016
        • 2905
        • usa
        What do you get at fuse with 2616 on top. Voltage Either side?
        • 2smoovedaddy
          • Aug 2012
          • 42
          No voltage on either side.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Need to make sure you are getting all your voltages to main board. Missing your 12v. Ether not getting it from power supply, bad regulator on main board or transistor or command to transistor is missing. Your 12v looks like it comes in on left side of ldvs cable through multiple traces so unlikely bad cable.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Can you list your power supply voltages giving legend name and voltage read.
              • 2smoovedaddy
                • Aug 2012
                • 42
                1. P_DIM1=3.27v
                2. N. C =0v
                3. Gnd=0v
                4. Gnd=0v
                5. UD =2.32v
                6. Blu_on =3.13v
                7. Gnd=0v
                8. Vamp=12.79v
                9. Vamp=12.79v
                10. Vamp=12.80v
                11. B13v=12.79
                12. B13v=12.79
                13. B13v=12.79
                14. B13v=12.79
                15. B13v=12.79
                16. B13v=12.79
                17. Gnd=0v
                18. Gnd=0v
                19. Gnd=0v
                20. Gnd=0v
                21. A5v=5.31v
                22. A5v=5.31v
                23. Gnd=0v
                24. PS_On=3.34v
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  The 12Vdc for the T-CON comes from the Main Bd. There is a transistor switch not being turned ON. Trace the line by continuity test from the T-CON fuse on the to the Main Bd. Then trace the Main Bd LVDS jack to find the transistor switch. That is how I did it twice already on other TVs I didn't have the schematic for.
                  • 2smoovedaddy
                    • Aug 2012
                    • 42
                    Are you talking about this area. I'm getting continuity on the pin shown in the pic. If so where do I go from there. Thanks!
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      It does appear as though the 12V Tcon missing supply is a main board problem and as Andrew said above, it's a matter of tracing the 12V supply from the Tcon and following its path on the main board.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        If you are only interested in fixing tv I would get another main board. If like me and it is hobby and learning experience then follow Andrew F. Ali advice above. Tracking mainboard problems can be daunting especially without schematics.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          How about a close up photo of that area but with the black heatsink lifted so that the components can be more easily identified.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            With the heatsink removed, trace that pin to its source. It may end at the transistor's collector or source depending if it's a bi-polar or FET type transistor. In my cases the transistor was open cct as the base or gate was getting signal/voltage.
                            • 2smoovedaddy
                              • Aug 2012
                              • 42
                              Here's a close-up. I'm getting resistance on the c,b,e on the transistor in the pic.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                What voltages do you have on those pins and when you bring it out of standby?
                                • 2smoovedaddy
                                  • Aug 2012
                                  • 42
                                  I'm getting 3.32v on the base, 3.29v on the top right( can't tell if it's base or emitter) and 0v on the top left. I'm getting continuity on the 4 bottom pins on the chip in the pic from the fuse on the t-con board. Also that chip looks like it has been replaced before. Might be refurb. Could the chip be bad and not regulating the voltage as the transistor seems to be fine per continuity check.
                                  • 2smoovedaddy
                                    • Aug 2012
                                    • 42
                                    Meant to post this pic of the chip.
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      For the ic you circled the first three from upper right side are source. Number four pin is gate and bottom pins are drain.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        What's the part number of the IC?
                                        Can you give the voltages Pin1 to Pin 8
                                        • stinger
                                          Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                          by stinger
                                          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                          04-17-2024, 03:06 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
