KDL-32BX300/APS-252 blows fuses
  • kturnerga
    • Apr 2010
    • 20
    I got a KDL-32BX300 Sony with a bad power supply. The fuse was not blown. No LED or anything showed up and the standby, etc pins on the supply tested a big fat goose egg.
    I ordered another APS-252 power supply. It arrived yesterday. I installed it, plugged the TV into the outlet and POW! I ohmed the fuse and it was blown. I replaced the fuse and when inserting the line cord I saw a flash and heard POW!
    I noticed the cord has a little kinking but I had tested it (so I thought) and the analog meter tested that it was giving the board power.
    If this board has a rectifier where would it be? This is what I hear is a fault in some power supplies.
    Re: KDL-32BX300/APS-252 blows fuses
    No idea until we get good clear pictures of the boards and the whole back side of the TV showing how all the boards are connected together. So right now you have two bad power supply boards?
    • kturnerga
      • Apr 2010
      • 20
      Yep; both are bad. One was with a good fuse but would not show a power good LED or show any standby voltages. The replacement would blow fuses and not show a power good LED. After the fuse replacement (and this should simplify things) I had nothing but line voltage and the ground screw wire in the corner of the board for connections. It was bolted to the chassis. I plugged in the voltage and POW!.
      https://www.flickr.com/photos/746549...posted-public/
      Sorry; had issues with adding the image so I had to do hyperlinks.
      These are views of the replacement power supply board that blows fuses. The other power board looks the same.
      One more thing; Is the four-legged chip on the heatsink the bridge rectifier? I tested it on both boards and am getting different readings with the DVM on diode setting. I'll send you readings later when I retest.
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
        FF Series (Very Fast Acting), 0603 Size
        Features
        ● Very fast acting at 200% overload current levels
        ● Low DCR
        ● High inrush current withstanding capability
        ● Fiberglass enforced epoxy fuse body
        ● Copper termination with nickel and tin plating
        ● Halogen free, RoHS compliance and lead-free
        Applications
        ● Notebook computers and tablets
        ● Digital cameras
        ● Memory cards
        ● Toys
        ● Bluetooth earphones
        ● Portable electronic devices​...
        10-07-2024, 05:50 AM
      • BlackScreen_22
        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
        by BlackScreen_22
        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
        I had no problems connecting mosfets and capacitors,...
        08-27-2024, 12:46 PM
      • Michale32086
        LG 60LN5400 Blows TCON Fuse
        by Michale32086
        I could have sworn I posted about this before, but I can't seem to find the post..
        To whit..
        I have a 60LN5400 that came in.. Backlights work fine.. No display..
        Traced the problem to the TCON board.. Blown fuse..
        Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
        Got a new Main Video Board.. Replaced the fuse on the TCON..
        The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
        10-30-2019, 09:21 AM
      • dimis7
        LG 37LS5600 blows main fuse
        by dimis7
        Need some advice to troubleshoot this TV.
        PSU blow the main fuse F100, 3.15A.
        I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
        I checked with DMM for dead sorts but didn't found any.
        Checked bridge rectifier and seems ok.
        Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
        PSU p/n is EAX64405901 (1.6)...
        10-28-2022, 05:15 AM
