LC-60LE810UN Sharp
  • Samantha143
    • Apr 2017
    • 21
    • Usa
    LC-60LE810UN Sharp
    Hey guys i was given this tv from a family member and was hoping to get it to work. I was getting a error code of 1 long 1 short. After doing research it said Lamp error. So i decided to take it apart removed the panel and test the LEDs. I found one strip of leds that are bad. So i ordered the strip and installed it today. Tested it and tested the old ones AGAIN as well, and everything seemed to be good. Put it all back together again turned it on and still getting the same error code. I tried reseting the TV by holding input and vol - on panel it self and nothing. Still same error message. What i dont know is this tv is the quantron sharp and the buttons light up white when in working state. Its a touch screen buttons not physical buttons. Could that be the reason its not allowing me to reset it? Or if anyone has any suggestions i would greatly appreciate it.
    Samantha
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LC-60LE810UN Sharp
    How did you test leds? Have you tried powering it on with panel off to see if they all work
    • Samantha143
      • Apr 2017
      • 21
      • Usa
      LED tester. I can test indivial LEDs or the whole strip. No i have not tried that. I assumed that testing the LED strips it would show me if one was bad or good. Thats how i found the one strip bad.
      • dskall
        • Oct 2016
        • 2905
        • usa
        That's what I use. Testing individually is the least accurate. I like to test from the connector off the powerboard. That way you are checking for bad connections in whole circuits. That doesn't guarantee they will work under actual load from tv. So it is still possible to have bad leds
        • dskall
          • Oct 2016
          • 2905
          • usa
          To go any farther will Need good clear straight on pictures of back of tv with cover off and each board.
          Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
          Format:
          Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
          1 - XXXXXXX - XXv - XXXv
          2 - XXXXXXX - XXXv - XXXv
          3 - XXXXXXX - XXXv - XXXv
          4 - etc.
          Picture of led connector
          • freakaftr8
            • Oct 2012
            • 3743
            First of all this is a very tricky television and it's got a lot of quirks. I repaired two of these. One that I repaired 3 years ago and still up on the wall at my mother-in-law's house working perfect. The LED that goes out is always the top right-hand corner on the right side LED strip. These buttons don't like to make good contact with your fingers because they're touch sensitive and quirky at best.
            Now if you unplug the TV without clearing the lamp error code as soon as you plug it back in it will illuminate the 1-1 error again. What I do is I use the palm of my hand and rub the crossed all the buttons to make sure it gets super warm. Then hold down the volume down and input while you're plugging it in as soon as the inverted V comes up solid, release both buttons. This should bring up astatic White Noise screen with the service menu. Then you arrow down to the lamp code fault in clear the error that way.
            I should note that it takes multiple tries but eventually you will get into the menu. This cannot be achieved unless you're holding these buttons down while plugging in the TV at the same time
            • Samantha143
              • Apr 2017
              • 21
              • Usa
              Hey guys sorry i was out of town hadnt had a chance to mess with tv till now. So i finally got the tv to turn on. Thank you so much guys for the info to reset the lamp code. But now i am having this issue with the tv. I am getting verticle color lines on half the screen. It stops directly in the middle of the screen. I tried taking the best picture possible. Sorry about the movie i got the first one i could find. 😁. After doing some research people saying its possible it can be a TCON?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Try cleaning and reseating all the Tccon ribbon cables.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  +1 since you had panel and t-con ribbon cables off may not have got them reseated just right.
                  • Pipolups
                    Corsair K70 LUX RGB dying LEDs
                    by Pipolups
                    Hi there !
                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                    10-08-2024, 11:58 AM
                  • DRIFT-O-MATIC
                    Sharp LC-40LE431U Manual control buttons not working properly
                    by DRIFT-O-MATIC
                    I have a Sharp LC-40LE431U TV. The symptoms are when plugged in, the control buttons on the right side panel don't seem to want to work correctly. I get a solid red light. But when I press the Power button, it does not power on immediately. I have to keep pressing ALL the side buttons randomly until finally the solid green light is on. Then when pressing each additional button, they do not always respond correctly, if at all. Pressing the Volume button might bring up the Menu, or vise versa. Even if I can get the Menu screen to come up and scroll through the selections, I still cannot select any...
                    02-14-2022, 04:24 AM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • JayPoorJay
                    Sharp 70' LEDs Spike 260v at start up?
                    by JayPoorJay
                    Hi all. This is my second thread. Have a bunch of questions.
                    I got my hands on a 70 inch Sharp Aquos LC70EQ10U. Not working when I found it.
                    I replaced the power board (found in eBay) and the TV finally produced an image. Reset it had image and sound.. Went from 2 slow and 2 fast blinks as a fault code to 1 slow 1 fast fault. Lamps or inverters according to the manual. TV is one now, at this moment (looks great w/ ZERO dark spots on screen) but it powering up and producing an image is unpredictable. 3 out of 10 times.
                    There are 3 leads to the LEDs....
                    02-01-2022, 05:04 PM
                  • beetle1303
                    Sharp 60LE630M DPS-165HP-2A: No Backlight
                    by beetle1303
                    I have a Sharp model LC-60LE630M that has no backlight.
                    When connected to wall socked and switched on, the red standby light is on. Pressed the power button, the green light is on for ~10sec then start flashing red light 1 time slowly.
                    There is no picture, no sound, and no light. But with a torch light, can still see the no-signal fizzle pattern.
                    I have tried the "forced on" combinations like pressed and hold Vol+ and ChnDown, and Input and Vol- buttons , no effect..
                    I disassembled the TV to check on the led strips. There are 4 strips of...
                    08-30-2021, 04:03 AM
