Still wasting my life on this one but I've forced everything on at P813, end result is the same as in the TV except instead of quitting after 3 powerup cycles, it continues so the mainboard must quit powering up , 3 strikes, you're out.
it has
Stdby 3.4 - 5v on run
M17V is present, M5V is on, Err Det (not used) is 4.9V, AC DET is also Ok 4.9V
VA, VS zippity do dah
I've swapped L6599D, R2A02117 and the micro all from a good board , no change
I've managed to spike and kill ZD301 several times now probing the optos, that kils the 17V around IC301 and rapid endless cliking.
I've confirmed the micro off the bad board is ok as the good board runs just fine using it.
Oh and the 60" is running fine, no idea but ever since I jumpered that one and forced it on, it's been fine, WTF, bad caps?
You forced it on and all of sudden tv works fine? if so weird indeed i had a samsung 21' monitor do something similar except when i replaced caps on it and a pair of fets it wouldn't work so while it was plugged in and turned on i started to wiggle components caps, and connectors and no go...... so more wiggling then on inverter i wiggled a cap all of sudden it made a spark arc sound and it worked flawlessly ever since. just little touch up on the joint and all was well even though the joint looked ok. weird
Yeah, hard to trust this POS. Great picture though plus this one has had the mainboard replaced with a measly 260 hrs so with a new PSU could get 5-7 years from it
I replaced zd301 and it solved the rapid clicking.
Now I get the normal slow click and retry. click click red light dims slowly as it shut off both relays. The normal problem you know.
EXCEPT : I THINK this is mainboard related. Why? Because I can instantly start the tv if I probe the 5.1 rail at the mainboard connector relative to chassis ground.
I bet I could put a 10Meg resistor and it would work flawlessly
Dear all, finally I found the culprit of cycling relay. I have checked and change all the high esr elcap and still clicking. I found that there is a bad joint in the T901 transformer. After resoldering the joints its back to live
I know this is a really old thread but thanks hartonoh for this post. Everything discussed her previously checked out on a power supply I have here and this put me in the right direction. I'd already inspected for cracked joints and overlooked one on one loan leg for T901.
